Home > General Chat > MED Management S Damper photos fitted?
tomkidd
Member #: 1962
Lancaster
Hi all,
Does anyone have any photos of one of these fitted to an engine with a sensor etc?
There is some about mate, i have seen them.
tomkidd
Member #: 1962
Lancaster
Hopefully they'll show up soon, I've been searching for weeks... *wink*
danrock101
Member #: 9277
Nottingham
found this on MEDs site
http://www.med-engineering.co.uk/catalogue..._5081%20(2).JPG
taaadaaa......
Edited by wolfie on 21st Feb, 2011.
that looks so good.
That'll never work, the fooking sensor isn't even connected,
tomkidd
Member #: 1962
Lancaster
Cheers Gents, I was wondering if there were any 'real life' shots with alternator belts etc attached and experience of fitting them... I've been put off the MED sensor because of the problem clubbie70 is having and KAD say that there sensor bracket allows for the trigger wheel at the outside face of the damper/pulley not the inside like the pulley above...
tomkidd
Member #: 1962
Lancaster
*laughing* *laughing*
Rick.SPI
Member #: 8027
That looks fucking brilliant.
EricsAmerica
Member #: 7891
Annapolis, MD USA
I've got the KAD fluid damper on mine with the teeth made into it. Just got the parts together with the sensor holder to get moving further on the project. Here's a pic of the damper....unfortunately, it's fookin expensive though. Not sure if I'm going to need to make a custom bracket or not as I run an A block....most of the pics I have seen are A+....
Edited by EricsAmerica on 22nd Feb, 2011.
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
From the looks of that I can't even see what belt would fit. there's no belt grove?
1380rich
Member #: 4755
warwickshire
Cheers rich
tomkidd
Member #: 1962
Lancaster
On 22nd Feb, 2011 1380rich said:
Cheers rich
Cheers Rich, will you be using megajolt?
1380rich
Member #: 4755
warwickshire
I use dta but same difference lol
Rick.SPI
Member #: 8027
On the gold one it's between the silver part and the trigger wheel :) well looks that way on the website
clubbie70
Member #: 8935
netherlands
clubbie70
Member #: 8935
netherlands
had to modify the bracket though so tha the missing tooth aligned with the cam on the breathercase
Rick.SPI
Member #: 8027
I was looking into getting this damper, but i don't like the sound of modifying it. :s
clubbie70
Member #: 8935
netherlands
i did only some minor modifying to bracket
1380rich
Member #: 4755
warwickshire
Mine went straight on, are you using the med trigger wheel pulley?
clubbie70
Member #: 8935
netherlands
yes :)
nibble36
Member #: 4273
stoke on trent
mine went on no probs no mods only to remove the tooth
rich are you scared a core plug may fall out.
1380rich
Member #: 4755
warwickshire
Lol I seen them on one of my engine builders old blocks and said they looked pretty cool... Picked my motor up and he'd put them on :)
