Home > General Chat > engine colour and rocker cover
mr brightside
Member #: 9376
birmingham
hi can someone tell me how much power i will lose if i paint my engine green and dont fit a alloy rocker cover thanks:)
Oli
Member #: 1910
Wilts
none, you will gain.
If you give it a red undercoat you will be fine.
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
and even more if you paint it red *tongue*
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
mr brightside
Member #: 9376
birmingham
what about the metro rocker cover can this be remeved from the engine *Sick*
alaskanow0
Member #: 8466
Mansfield
You will gain, because the standard rocker cover weighs 500g less
Jack2eaton
Member #: 9772
Sheffield
Am I being stupid? How can colour effect power?
shellspeed
Member #: 9580
Surrey
It just does ! Like brake calipers.
wng691s clubby
Member #: 9252
Cleethorpes
calipers have to be bright red otherwise youll get no stopping power
Done now needs redoing lol
Shit mine are blue, i did wonder why....
Edited by MikeRace on 1st Feb, 2012.
Blue for extra cooling
Red for more power (or to sell at over-inflated prices on eBay.
BMC green if your car is an early gay model
Black if you want it to look lovely and prevent the need to ever clean it.
Grey if you are Will H
Combinations of the above work as undercoats or a mix. Eg purple will give cooling and power benefits, but only half the power of red or half the cooling of blue. Undercoats work better as you can do a complete coat of red and a complete coat of blue, netting you all the power and cooling rewards!
Oh and don't forget Matt black on your intercooler for 1000% more heat dissipation.
Miniwilliams exploits the benefits of colour on his 300hp monster. Check out the attention to detail, with different colour head and block. We can only assume that metallic blue has aerodynamic properties and gold aids traction.
This is all proven and tested. 100% factual.
Edited by theoneeyedlizard on 1st Feb, 2012.
pre 80s engines where black. its the early gay ones that where green
Thats why they painted the mincey thows yellow.
Nothing thats yellow is hard or manly!
Thanks Andy. I've edited my post so that I've got this list properly accurate.
good work Gary
bennyy
Member #: 9037
Doncaster, yorkshire
It's a tough call, purple = 50% power and cooling, or do red and blue for max. Power and cooling, but with 100% more weight in paint??
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Van had a red block and a blue head. So does my clubby. *smiley*
t@z
Member #: 452
Chester, UK
my rocker is purple, engine and head are green but the head has blue under the green and blue lighting coming through!!!
im so ahead of paint technology its unreal
www.twitter.com/lilpinkiy
My old engine block was green overpainted red. Then the head was green, overpainted blue, which was then overpainted red.
New engine will just be black.
tadge44
Member #: 2500
Buckinghamshire
My engine is gold -does that just make me odd ?
But you may have noticed - I do like to be different.
wintersurferuk
Member #: 2208
IT'S GGGOOOLLLLDDDD!!!!
Sholty
All the above is true. And it's definatley a fact that grey 998s is the way to go.
Not sure about the gold, but it may work on an in-line engine rather than the transverse mini orientation.
I used some 2k etch primer on my gearbox casing. It was a shitty yellow/green colour, left over from the days before they banned chromates in paint.
The top coat was black.
What does this do to the performance of my gearbox ???
Also, the black is chipped in a few places exposing some of the shitty yellow/green - does this enhance its effect ???
