| Home > Help Needed / General Tech Chat > Running problems, running on 2 | |||||||
25th Jun, 2011 at 11:05:16pm
Chaps, my cars only firing on 2, a couple of days ago i found thos issue, i checked all the wiring on my mj and everything seemed good. After some convos with john boy i finally discovered that my coil pack had to be plugged in 1 to 4 from left to right not right to left! Which says to me the wiring was the wrong way around perhaps. Any ways the car ran fine upto about half hour ago. Ive had the clutch out put it back and now its back to square one.
25th Jun, 2011 at 11:07:33pm
which 2 are not firing,
Yes i moved to the darkside |
25th Jun, 2011 at 11:08:23pm
One side of the coil pack u/s?
25th Jun, 2011 at 11:13:31pm
Both left hand cylinders are out, 4 and 3 are doon, ive tried 3 coil packs and all are the same. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
25th Jun, 2011 at 11:47:56pm
Ford coilpacks fire 1 & 4 together and 2 & 3 together - hence them being called wasted spark - there are only two coils in a coilpack, not four......
26th Jun, 2011 at 12:01:59am
Its never been an issue, however ive tried a different edis to no avail, the only thing ive done is lengthend the coil pack wiring, however im almost certain the wirings correct, i think im gunna swap the wires over tomoz to double check.
26th Jun, 2011 at 12:49:42am
like rod says though even if youd fucked up the wires, 3 and 4 cant be the same fault because its on different coils Yes i moved to the darkside |
26th Jun, 2011 at 08:51:36am
If its never been an issue before, it may suggest either leads breaking down or plugs???
26th Jun, 2011 at 09:48:03am
Yeah got a multi meter. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jun, 2011 at 09:52:22am
Have you used shielded wire for the bit you extended? Did you join the shield? Could be getting interference. Got loads throwing round if you want a bit of new to try On 11th Feb, 2015 robert said:
26th Jun, 2011 at 09:57:18am
Didnt think the coil pack one needed to be shielded? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jun, 2011 at 10:12:10am
No, you're right. It's the pip/saw wires all the way up to the MJ that are shielded. On 11th Feb, 2015 robert said:
26th Jun, 2011 at 11:27:16am
mike have you "seen any" spark on the two plugs ......daft question ?
26th Jun, 2011 at 11:31:50am
Check the resistance of the lead cores end to end, see what they measure On 7th Nov, 2011 apbellamy said:
26th Jun, 2011 at 06:15:26pm
Well ive been at it all day, tried different leads plugs etc etc, spark on all cylinders and plugs, however if i remove 3 and 4 plugs, nothing, remove 1 and 2 and the engine splutters? Ive also checked compression, no probs there, ive also checked for leaks between the manifold and head, however i would have thought that would cause such a huge problem.
26th Jun, 2011 at 06:30:57pm
Sounds like the head gasket has blown between 3 and 4, but the compression test would suggest not?
26th Jun, 2011 at 06:40:01pm
Too much Bass draining the power Mike lol? On 5th Sep, 2011 Vegard said:
26th Jun, 2011 at 06:44:01pm
26th Jun, 2011 at 07:24:29pm
did you do the comp ceck with both plugs on 3 and 4 out ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Jun, 2011 at 09:32:11pm
Yes all plugs removed, on a side note the misfire appears to have shifted to oposite side? My widebands off the scale lean?
On 26th Jun, 2011 robert said:
did you do the comp ceck with both plugs on 3 and 4 out ? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jun, 2011 at 09:34:30pm
Lean misfire? Try richening up a touch. If something is worth doing, it's worth doing half of. |
26th Jun, 2011 at 09:42:00pm
Even on choke? Would having my wideband plumbed into my mj without any data set be an issue? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jun, 2011 at 09:44:36pm
Are you sure that the plugs are ok.
In the 13's at last!.. Just |
26th Jun, 2011 at 09:47:45pm
There new, tried a different set which made no difference, thanks for the input so far guys. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jun, 2011 at 11:03:03pm
You sure you havnt got an air leak somewhere? On 7th Nov, 2011 apbellamy said:
