Home > Help Needed / General Tech Chat > Boost modulator
diddy
Member #: 505
Stockton-on-Tees
Just a general query, what exactly does this do??
diddy
Member #: 505
Stockton-on-Tees
Sorry posted wrong picture. This is the one i meant to post
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
limts your boost mid range...
WOrks with the std ecu from the metty turbo!
Alex
AlexF
or to put it another way, allows more boost after the mid-range.
LOL!
cheekym0nkey
Member #: 180
Northants
Can these be wired in to work without the ecu? so you can turn the boost down with the flick of a switch?
minimark
Member #: 19
newcastle
yes
minimark
Member #: 19
newcastle
stick it before your bleed valve
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Yup...
very simple two stage boost controller!
Alex
AlexF
minimark
Member #: 19
newcastle
developed by BIR and used by BIR1 and 2 , turbodave , JF , Jimster , Andy C , and many top turbo racers !!!
Edited by minimark on 6th Apr, 2005.
minimark
Member #: 19
newcastle
sorry about above post thats just bullshit from my company advert ....
half the above people never have or never will have one of my 2 stage boost kits but it sounds like they all do ......lol.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
good thing I didnt claim I just invented it :p
alex
AlexF
minimark
Member #: 19
newcastle
i`ll give it a few weks before your offering the conversion ...........lol.lol.lol.
just don`t do a morspamspeed and claim to build all the engines they have ......
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
pmsl!
why not...
AFRacing Ltd needs some more work *wink*
Alex
AlexF
minimark
Member #: 19
newcastle
about ?5k i hear ....
minimark
Member #: 19
newcastle
actually whats the turnover limit before you have to be LTD ??
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
LOL yeah got fund the Mini addiciton *wink*
limit wise... none.. you can earn anything and be a sole trader... but you'll need to be VAT registered if your turnover exceeds about 55k a year.
Alex
AlexF
diddy
Member #: 505
Stockton-on-Tees
Alex
So is it just a valve thats controlled by the ecu?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Its a simple soleniod (sp).
If you wanted to you could make a variable boost controller with some simple elctronics to drive the valve at different frequiencies!
Alex
AlexF
diddy
Member #: 505
Stockton-on-Tees
So the solenoid in the top picture ( that i didn't even mean to post), that must be the carb vent valve is it?
Just asking this cos when i bought my engine it came with two boxes of parts, one was the ordinary ancillaries that you find on most mini engines, and one was full of pipes and valves and other interesting bits related to the turbo!!
I think BIR1 is fitted with one of these fantastic power valves.
You just wouldn't believe the diffference it makes.. The car flies, and spins in fourth now..
yes the top pic is carb vent valve or anti run on valve
lol @ vegard
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Are you allowed to do that in Norway?
Alex
AlexF
oh, so NOW it spins the wheels in 4th!
LMAO
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I found 4psi to be fairly slow in mine...
Certian no wheel spin issues *wink*
Alex
AlexF
