Home > General Chat > Can anyone tell me how much a engine rebuild will cost me
ash1275
Member #: 6883
mansfield
I brought a metro turbo engine a few month ago and want it rebuild but av no idea were who or how much it will be can anyone help me?
Are you intending to rebuild it to a standard spec?
What power are you after as this will have a significant affect on what needs replacement/uprating.
ash1275
Member #: 6883
mansfield
Hi m8
I don't really want it standard
But it all depends on the price
for a standard rebuild including gearbox if you do it yourself I imagine you could do it for £1500 with new pistons, reground crank new gearbox cross pin diff etc. which should see a reliable 120bhp.
if the engine is in good condition and only needs bearings, rings and a gearbox probably a lot less.
ash1275
Member #: 6883
mansfield
If the engine is in bad condition do u think it would be worth buying another one.
I'm not to good with the engines so wouldn't be doing it my self
alaskanow0
Member #: 8466
Mansfield
Hi Ash1275, Im in mansfield, I can offer to help you strip and access what you need. It could cost you anywhere from £500 for a very basic rebuild to around £5000 if you are after big reliable power.
well if you got 4k lying round then there is a very nice spec unit in the for sale section at the moment.
As long as you engine is not totally fucked your better off rebuilding it unless you can really vouch for the unit you are buying. With a fesh rebuild it is not worn and has not been run with an incorrect setup (ignition/fuel) possibly causing damage.
ash1275
Member #: 6883
mansfield
thanks
i dont no if the engine start or anythink really would appreciate ur help
ash1275
Member #: 6883
mansfield
unfortunately i dont av 4k :(
when i bought the engine i was told he only just took it out and it was running fine but due to my mini been resprayed i avnt had it put in and i want to make sure it is ok so i dont av the risk of damaging the spray shell
Craigie-B
Member #: 9468
Wootton Bassett
Spent 2k on mine so far and still going *frown*
Do you know this letter? HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH??????????????
Edited by Nick on 8th Oct, 2011.
Yes he does. He said "Had". Play nicely with new people Vegard.
Craigie-B
Member #: 9468
Wootton Bassett
Mines cost 2k so far and ive done the following:
Rebore to 40
New omega pistons
New 266 cam kit
All new gaskets
New oil pump
New water oump
Painted the block
New bottom end bearings inc big, main and thrust brearings
Gt28 turbo
Ive got so many parts lying around ive forgotten whats what
Basically when im done the only thing to to be new/refurbed is the crankshaft and the pushrods
2000 so far im expecting another 400 - 500 and itll be done *smiley*
bennyy
Member #: 9037
Doncaster, yorkshire
Do you have a spec or budget you want to aim for, what is it intended for? Road use, track use? Drag etc etc?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
ash1275
Member #: 6883
mansfield
It will be used for the road.
I'm not sure on a budget would like cheap but good if that was possible
ash1275
Member #: 6883
mansfield
Sorry vegard or spellcHecker wHicH ever you profer
I'd strip down what you've got first and see what you've got to play with as this will have a significant impact on any build.
You could build a budget engine with pretty stock parts as I have but i was lucky my pistons and block were good to be re-used (only needed rings) and a cheap standard crank. Yes, you could go for a re-bore and new shiney pistons with the price tag to match
As for a cam, if money is tight, you could use a s/h MG n/a cam to good effect. Many use the avonbar turbo cams (forget the number at the moment).
Head; again this will all depend on how good the head is to start with but you could start off with simply opening up the chambers to reduce the compression. There are a couple of guys on the forum that have been modifying these to good effect; have a look about and your find out who to talk to.
Ignition; consider megajolt if you can but plenty will still be using the original set-up.
the options are so varied and everyone has a differing opnion of what they consider good for use on the road etc, I'd do some research on the forum and get some ideas on what you really want.
ash1275
Member #: 6883
mansfield
Thanks rob I will have a good look around befor I make a move thanks :)
no probs.
wez
Member #: 9271
Stoke on Trent
i think you may find this useful, http://www.turbominis.co.uk/forums/index.php?p=vt&tid=214604
Edited by wez on 8th Oct, 2011.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Mr Joshua
Member #: 1954
Luton Bedfordshire
I have run the numbers a few times and the best route you could go down is to buy an engine kit from Mini speed.
Check out the spec of the parts included and then phone round and see home much it will cost to put it all together
Own the day
ash1275
Member #: 6883
mansfield
Thank u mr joshua I will av a look
I would say from experience that it's well worth teaching yourself the basics, reading as much as possible, then just getting stuck in and do it yourself.
Out of everything I've done with my car, building the engine was the most enjoyable and rewarding experience.
You may not have already noticed, but a lot of users of this forum don't react well to "txtspk".
That is because most of us use a PC and have a querty keyboard and know how to use it. Those who use mobiles etc. generally take the time to spell and do grammar properly for the benefit of the majority.
Back to your original question, if you don't have the skills (or don't want to learn them) then you are going to pay a significant premium for someone else to do it for you and, unless they are well respected, you might end up with something worth less than you started with.
[pedantic comment]I don't think many of us have a querty keyboard Rod.[/pedantic comment]
