| Home > General Chat > OT - Electric motors single / 3 phase | |||||||
29th Apr, 2005 at 11:39:15am
I've got the chance of a 3phase two poster lift for my work shop. but I only haver a single phase supply, a single to three phase converter man enough for the job is around ?400, so I was thinking of changing the motors to single phase. I may be wrong here, but I think you can run a 3 phase motor in fwd and rev, but I think if you have a single phase ac motor, which ever way around you power it (normal or reversed connections) it will always run the same way. Is this correct? Edited by Jimster on 29th Apr, 2005. Team www.sheepspeed.com Racing
29th Apr, 2005 at 11:52:34am
single phase motors to match the same hp as 3 phase motors are expensive and a lot larger so im lead to believe. Hence larger hobby compressors (3hp ish) use 3 phase convertors on the top.
29th Apr, 2005 at 12:00:14pm
I'm getting a quote to get 3phase installed in my garage (which is next to my house in residential area) does anyone know if this will be silly money? Team www.sheepspeed.com Racing
29th Apr, 2005 at 12:09:22pm
29th Apr, 2005 at 12:12:42pm
I thought so, so how do single phase lifts work when you want to make them go down? Team www.sheepspeed.com Racing
29th Apr, 2005 at 12:16:12pm
Gravity.
29th Apr, 2005 at 12:24:14pm
yea good point, maybe they have small ac dc transformers in them? Team www.sheepspeed.com Racing
29th Apr, 2005 at 12:32:49pm
An electric drill is really a d.c. (or universal motor). You reverse them by reversing the connections to the field or armature, not the supply as piontes out above.
29th Apr, 2005 at 12:40:16pm
A single phase motor will run in both directions, it just depends on which direction it starts. Unfortunately the starting mechanism is normally contained within the motos so it will only go one way.
http://www.twin-turbo.co.uk
29th Apr, 2005 at 01:36:05pm
There is a way to convert a three phase motor to use single phase using capacitors, yes. You need to use the capacitors to make the single phase "lead" and "lag" in phase from the orignal supply to effectively give you three phase. However in doing this the motor effectively runs at less than a third of its output power on "proper" three phase. In some applications you can get away with this, for a car lift i think you would struggle.
29th Apr, 2005 at 01:56:11pm
I am actually close to wear there is 3 phase, I'll await my quote Team www.sheepspeed.com Racing
29th Apr, 2005 at 01:57:58pm
OK. If you want some ideas on how to wire a panel to control it if it hasn't got one let me know.
29th Apr, 2005 at 02:02:20pm
mate, i think you'll find its about 6k..... |
29th Apr, 2005 at 02:12:24pm
ouch! think maybe I'll buy a new trolly jack instead! Team www.sheepspeed.com Racing
29th Apr, 2005 at 02:29:19pm
The other thing to do I suppose is get the shaft size and HP (kW) rating off the motor and price up a single phase item to do the same job......and then think up some ingenious way of lowering it off........
29th Apr, 2005 at 02:37:40pm
yeah i guess, much of 3hp and you'll be struggling i reckon. well for a sensible price |
45 Posts Member #: 446 Member Burntwood Staffordshire |
29th Apr, 2005 at 06:04:29pm
Use 2 single phase motors attatched to a common shaft
29th Apr, 2005 at 07:33:03pm
Big diesel starter motor and a few batteries
568 Posts Member #: 102 Post Whore Pennsylvania USA |
30th Apr, 2005 at 12:05:31am
Hi
39 Posts Member #: 444 Member |
30th Apr, 2005 at 09:58:28am
hi jimster
30th Apr, 2005 at 12:49:36pm
my nieghbour has a 2post lift that is 3 phase, they bought a converter like you talking about that was around £400. however it isnt able to cope and you have to stop to let it cool down
30th Apr, 2005 at 05:01:41pm
if you could find out some info nick, that woudl be great Team www.sheepspeed.com Racing
30th Apr, 2005 at 10:05:52pm
When you get the quote for 3 ph Jim can you let me know a rough price, just out of interest for future plans.....
1st May, 2005 at 11:09:28pm
look into invertors and single phase motors. i did a class on power engineering, and learned how to converto 3ph motors to 1ph, and al the asociated maths, but that was 2 years ago and iv forgot :(
3rd May, 2005 at 02:01:40pm
I was speaking to a mate on the weekend, who told me that he has many times reversed the polarity on a single phase motor and made it run in reverse. Are we wrong, or his he talking crap? Team www.sheepspeed.com Racing
