Home > Help Needed / General Tech Chat > Water injection
Would a tapping into the intercooler end tank (the end which is fed by the turbo) be a good option?
In the inlet. Any further away and you'd risk pooling I would have thought?
Craigie-B
Member #: 9468
Wootton Bassett
Nice, Sig'd *wink*
what does the nozzle look like?
I'm thinking in th back of the plenum pointing down the carb.
Hmm, I thought that it was common to place it into the intercooler.
Would pooling be an issue? I'd not trigger it until boost reaches 20psi +. I was hoping that the speed that the air will be moving once this boost pressure is reached should prevent it.
I'm not collecting it until later, so won't know until then.
I'll be a pic up once I have it in front of me.
http://www.methanol-injection.co.uk/where-...tion-nozzle.php
on the outlet of the inter cooler is a common place for it as it gives time to atomise, what tom says is valid but in theory it will only be spraying at high air flow
imo straight into the carb would be good aswell
TBH peple stick it everywhere... and theres merits to each..
if you stick it pre turbo you can actually make the turbo more efficient especially on somthing small, if you stick it just after the tuorbo your injecting at the hottest point so you stand the best chance of scrubbing off heat. if you stick it in the inlet you wont get puddling ect.
have a play with the WI part of the the motorgeek calculator?
http://www.motorgeek.com/?fullpage=true&page=flowcalc
Fishing for someone to sig that??
PMSL I didnt even notice that was filth!
Craigie-B
Member #: 9468
Wootton Bassett
Lmao
Mine is going straight in the back of the charger, but I'm doing gay suck through.
Can put a picture up of my nozzle if you like.
tadge44
Member #: 2500
Buckinghamshire
I always favoured two nozzles, one in each inlet, aimed at the valve.
wez
Member #: 9271
Stoke on Trent
thats a good one *wink*
one day boost will be mine!
jamie@thefatgarage
Member #: 9345
Sheffield
There are all sorts of reasons to move the point of injection around depending on how you intend to tune the engine to take advantage of it (before or after IAT etc). General wisdom is inject into inlet manifold after TB/Carb and adjust your tuning to suit rather that just use the water to cool what the IAT reads and let it do it.
https://www.alcohol-injection.com/en/conten...njection-nozzle
read that.
Snap :)
Spoken to (a very helpful) ERL.
The chap I spoke to said it would be best after the intercooler and before the plenum.
This gives the water time to atomise apparently.
topcat
Member #: 9408
Tiptree, Essex
Would you get better heat transfer by injecting it before the intercooler?- the hottest air, and by having a higher moisture content it could shed more in the intercooler?
Perhaps not, but thinking aloud...
www.topcatcustom.co.uk
Surely the water will collect in the intercooler if you inject it before ?
Phil, You and Tom are correct according to ERL.
topcat
Member #: 9408
Tiptree, Essex
Yeah I thought about that, but the heat and velocity may stop it- it was just a scientific thought anyway!
ahem *happy*
mine will be going a tiny bit pre turbo and alot post intercooler :)
Sorry. Yes Brett you are the most correct *wink*
Craigie-B
Member #: 9468
Wootton Bassett
so you know where to put your nozzle now? Boom Boom Speaker Policeman :)
