| Home > General Chat > 12g202 is it worth doing up for N/A? | |||||||
3rd May, 2012 at 08:57:49am
i have a 1098 and im wanting to know if i should keep my 202 or go 295? the 202 is in good shape its stock as far as i know i will measure the valves and thickness of the head its self tomorrow as i still need to clean it and its dark out
3rd May, 2012 at 09:09:31am
Number Inlet dia. Exhaust dia. Nominal cc Standard fitment
Edited by Chalkie on 3rd May, 2012. |
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
3rd May, 2012 at 09:20:32am
The chamber shape needs altering, as the standard size valve is shrouded now, if you put a bigger valve in without altering the chamber you would end up with a worse head. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
3rd May, 2012 at 11:39:38am
Wez is correct. The chamber needs to be 295spec. Bigger inlet and exhaust is necessary. Minispares sell these quite cheap. On 13th Jul, 2012 Ben H said:
3rd May, 2012 at 07:15:57pm
The 202 can be made to work well, it just requires a bit more work than the 295, though they can be picked up for peanuts compared to the 295. |
3rd May, 2012 at 11:11:49pm
ok so what size valves should i be looking at installing given i or someone de shrouds the head?
4th May, 2012 at 06:49:54am
I started modding a 202 using the stencil from vizards other book, I've still got more to fetch out of the chamber and it's already 28cc, I'll guess it would be 30ish maybe more once opened out to the suggested shape so for n/a it will need a skim to bring it back to a useable cr. one day boost will be mine!
4th May, 2012 at 06:55:40am
ok the head is about 2.737" think factory heads should be about 2.75" and i should have at least 0.080" buffer after skimming the head witch is measured down the rocker oil feed hole after measuring my head 2.555" that leaves .182" to skim to get a CR of 12-12.5 as recommend for max power "if you cant get much in there then squeeze the heck out of what you can get in there" so that should be enough meat depending on how nuts i de shroud it right?
Edited by Turbo This.. on 4th May, 2012. |
5th May, 2012 at 07:43:41am
ok so i have ground chamber number 4..
Edited by Turbo This.. on 6th May, 2012. |
5th May, 2012 at 09:29:58am
if your using it for n/a then 8:1 will be to low especially if your using an uprated cam, thats what i meant when i said it will need a skim. but 8:1 cr would be a shame to waste it....... get a turbo on it. lol
5th May, 2012 at 09:39:04am
thanks man well i have had thoughts to ad a turbo lol but i really don't know what is involved and what gains there are at what stages like from a basic blow throw carb and dissy to fuel injection and a computer running the show
5th May, 2012 at 12:07:51pm
Good effort so far, looks like you're on the right track. A small bore head gasket will probably be around 2.8 - 3cc volume I would think. |
5th May, 2012 at 09:28:04pm
ok thanks phil
7th Jun, 2012 at 09:31:07am
well i have been busy with work (installing solar electric systems) so the mini has gone no where how ever i have the day off tomoz so i plan is to get my electrical license sorted as im fresh out of tafe and just need to do paper work after that i need to ring around for new suspension bushes for the work ute as they are almost non extant ! its a 87 model Toyota hilux then if i have time i shall do my dammed to finish the head get it the the shop for a shave and all that fun stuff im having withdrawals from not driving the mini ! |
8th Jun, 2012 at 09:46:31am
well i got my sparky license sorted =D YAY!
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
13th Jun, 2012 at 07:29:29pm
I had in mind the beak radius needed to be bigger than the way you did it.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
14th Jun, 2012 at 09:54:45am
advantage: yess i think your right now that you point it out i had another read in the book and it recommends a 0.18" radius so ill have a measure and see what i have and fix it if need be = D thanks for the heeds up i would have missed that if you did not point it out.. |
14th Jun, 2012 at 06:16:54pm
I agree, a slightly larger radius is needed. Other than that it looks a good effort. |
![]() 118 Posts Member #: 9965 Advanced Member Sydney, Australia! |
15th Jun, 2012 at 02:40:15am
Thats lookin fantastic! i love how much an individual stance can be made with these heads in regards to chamber shape/size...
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
15th Jun, 2012 at 08:18:06pm
On 15th Jun, 2012 mattsmadmini said:
most of the magic happens in the ports with this one rather than the chambers
Show us a pic of the ports then ! (or a link to your aussie forum) On 15th Jun, 2012 mattsmadmini said:
flows better than a stock 295, and just looks nice i reckon... helped my 1100 get to 54hp on the rollers... Which camshaft ? Rusty by nature
16th Jun, 2012 at 01:26:26am
Trying to find some port pics... and RE13 “A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
14th Jul, 2012 at 10:28:28am
well its been a while the other day i took my head to a local shop and they said id be up for all most 400 ausie bucks for a shave to get a comp somewhere in the 12.5-13:1 my instant thought where ok thanks bye of cause i looked around and found that meany other shops had no interest in a cast iron head ether much to my appointment's so im gona slap a turbo on it and be done with it! well more or less.. ill have some magnesium guides, re faced valves, 3 angle seats and a surface cut should do me fine i thing please let me know if im wrong!
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
14th Jul, 2012 at 12:09:36pm
magnesuim guides.. that should be very interesting That sir, is not rust, it is the progressive mass reduction system
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
14th Jul, 2012 at 03:08:56pm
a kim is normally about 80$ to 100$ i got a hold head rebuilt in oz for about 600$ lol..
14th Jul, 2012 at 06:23:27pm
Edited by Sir Yun on 24th Jul, 2012. That sir, is not rust, it is the progressive mass reduction system
