| Home > Help Needed / General Tech Chat > Heat location in the coolant system | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
11th Jun, 2012 at 02:31:22pm
Hey Guys!
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
11th Jun, 2012 at 02:36:14pm
heat rises, therefore the hot coolant comes out of the head and goes into the top of the rad On 11th Feb, 2015 robert said:
![]() 118 Posts Member #: 9965 Advanced Member Sydney, Australia! |
11th Jun, 2012 at 03:02:41pm
hot comes in up top
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
11th Jun, 2012 at 04:51:48pm
FUCKKKK
11th Jun, 2012 at 05:26:29pm
would I be able to join the water return to the inlet manifold then join the other side of the inlet manifold to the heater pipe?
11th Jun, 2012 at 05:35:30pm
yes, but you don't want to heat your inlet manifold up... On 11th Feb, 2015 robert said:
11th Jun, 2012 at 08:01:10pm
On 11th Jun, 2012 apbellamy said:
yes, but you don't want to heat your inlet manifold up... or do you?
Yes i moved to the darkside |
11th Jun, 2012 at 08:28:58pm
ohh I might do just to make my plumbing easier and tbh it might be nice in winter?
11th Jun, 2012 at 09:13:10pm
Whats the point of cooling your turbo if youre just gonna heat the charge in the manifold again?
I seriously doubt it! |
11th Jun, 2012 at 09:45:18pm
mm I do see your point paul
12th Jun, 2012 at 07:09:24am
yes, but you don't want to heat your inlet manifold up... or do you? ![]() On 11th Feb, 2015 robert said:
12th Jun, 2012 at 07:24:50am
With the air spends in the manifold and its surface area heat transferal will be almost zero i will argue that with a heated manifold the temp rise of the inlet air to be less than 1degree c
12th Jun, 2012 at 07:27:31am
I still say its bad On 11th Feb, 2015 robert said:
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
12th Jun, 2012 at 01:12:56pm
This is my set up, been out and road tested, and seems OK so far, only been to test center not had a proper run out yet..
Main Build
12th Jun, 2012 at 01:29:50pm
Take water FROM the bottom hose that normally goes to the heater. That water is as cold as it gets. Then route it ito the top hose. I'd also reccomend having the head heater output open, and plumbed in the top hose. On 13th Jul, 2012 Ben H said:
13th Jun, 2012 at 09:05:20am
what I have done so far is:
13th Jun, 2012 at 09:36:14am
I wouldn't return through the heater into the bottom hose. You will end up with a load of hot water bypassing the radiator. As V says, return into the top hose. On 11th Feb, 2015 robert said:
13th Jun, 2012 at 09:53:06am
I have one of these rads:
Edited by Craigie-B on 13th Jun, 2012. On 10th Mar, 2012 theoneeyedlizard said:
13th Jun, 2012 at 11:34:18am
water comes out of the head, through the heater and into the top of the bottom hose.
13th Jun, 2012 at 11:42:14am
doesnt it have to have a flat spot for that? Im using the rounded mini one:
13th Jun, 2012 at 11:46:52am
I make a new top hose with a branch from a standard bottom hose. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
13th Jun, 2012 at 11:50:35am
13th Jun, 2012 at 12:01:39pm
just been out and took some pictures of my house mates mini and old bottom hose:
13th Jun, 2012 at 12:18:21pm
So to get things straight, the water comes out of the bottom hose, goes up into the water pump pushed around the engine and then into the cylinder head then to the heater matrix and returned into the bottom hose, but some of it goes up the top hose and into the radiator?
13th Jun, 2012 at 01:23:04pm
