Home > Help Needed / General Tech Chat > Water/methanol with no Intercooler
mayoturbo
Member #: 1395
chepstow
Anyone running this? Seems to be a few benefits such as shorter inlet track, no hassle finding space where there is airflow and perhaps more consistent inlet temps
Edited by mayoturbo on 13th Jun, 2012.
I will be running it in early August if all goes to.plan. I'll be running a gay supercharger though *wink*
Even if you have a crappy side-mount intercooler it is better than none. Then use water/meth to compliment it.
Evoderby
Member #: 9987
Amsterdam
Best article I've ever read on the subject:
http://autospeed.com/cms/A_110213/article.html
Evoderby
Member #: 9987
Amsterdam
On The subject of intercooling:
When running an intercooler, basically there are two factors that lie at the basis of intercooler performance:
1. Intercooler effeciency = cooling capacity
2. Pressure drop = flow resistance
This means cooling the air comes at a price of added resistance in the flow path which can be measured in the way of pressure drop across the core. For instance 8 psi measured at the intercooler inlet, 5 psi measured at the intercooler outlet = 3 psi pressure drop.
Corky Bell of Bell Intercoolers mentions in his book Maximum Boost that a ample sized core shouldn't drop more than 1 - 1.5 psi , however some applications read as high as 4-5psi.
Intercooling can be a very worthwhile addition, especially when using extended periods of boost it requires a well thought out design with proper ducting (!), frontal area and core capacity....otherwise it both strangles the engine and heatsinks in no time losing all potential benefits in the process.
bennyy
Member #: 9037
Doncaster, yorkshire
Pretty sure this was about water injection/methanol?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Evoderby
Member #: 9987
Amsterdam
Have a look at the link I've posted, it mentions several scientific testing procedures on supercharged engines with water injection as a detonation suppressor. How about a 73% rise in BMEP before detonation occured, the possibility to run 80 octane fuel instead of 100 without problem as well as massively leaning out fuel mixture without adverse effect?
The comment on intercooling was ment as some additional info with regards to the "any intercooler is better than none" comment made in this thread.
Just some stuff gathered during my days of integrale ownership....
Ben H
Member #: 184
Melton Mowbray, Pie Country
The phrase this forum like to quote is that the intercooler is not the icing on the cake, it is more the cake.
This subject has been covered a lot though.
http://www.twin-turbo.co.uk
Evoderby
Member #: 9987
Amsterdam
BTW there's another interesting use of water; external intercooler spray to increase intercooling efficiency.
The early integrales evo1 came with such a system fitted for homologation purposes, requiring only a fuse to be activated. It was a rather crude system, being boost activated only therefore running out of water rather quickly....no problem during stage rallying with only a few km's between service.
A more advanced system which is much more efficient on the use of water can be found on autospeed in the intelligent intercooler waterspray series of articles:
http://autospeed.com/cms/search/index.html...t+spray&x=0&y=0
Enjoy
Ps I'll shut up for now*wink*
Yes intelligent intercoolers are the way forward!
Providing your not on a water meter....lol
Ben H
Member #: 184
The thing with all these systems is that before you should even consider them you should be looking at getting a good intercooler installed in the first place. Also for most on here they will not be running sustained boost for long periods so extra cooling should not be necessary. Fit the biggest cooler you can from a reputable supplier and you should be ok. With the space available on a mini it is difficult to fit one that is too big.....
I have one of these one my shopping list:
http://www.aquamist.co.uk/cp/H3.html
But only so that I can run high boost with 9.5:1 CR.
The biggest intercooler I can fit takes priority. The water injection will only be used once everything else is working properly, not to cover deficiencies elsewhere.
Evoderby
Member #: 9987
Amsterdam
My point exactly, given the limited space available in a mini fitting a cooler of both ample size placed within a proper flow path on a cool location can be challenging indeed. We could discuss and theorise on the subject all we want, I'd like to leave it at the fact that the techniques are there for those interested and that it only takes a pair of thermocouples and manometers to measure before and after cooler temperature & pressure drop to take any guesswork away and assess whether your system might benefit from additional measures.
It can be done well if you try hard enough...
bennyy
Member #: 9037
I have a custom alloy intercooler behind the grill, takes very little work to make it fit, and are very efficient.
We are currently fitting this to get some real data. I'm not sure a manometer is much use under full boost :)
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=398452
Or an example of a sensor mad install. Look on the inlet and outlet of the IC.
We've discussed IC type and placement plenty over the years, but it is fair to say that we have no all done that much monitoring. But we have done pressure drop tests on the bench on ICs and temp monitoring before and after on an install.
Edited by wil_h on 13th Jun, 2012.
Evoderby
Member #: 9987
Amsterdam
Wow, some very nice examples of proper installations indeed!!! Love the ducting on Madmk1's non- flipfront solution.
Will, your setup looks 1000bhp-skyline-nice *wink*
Evoderby
Member #: 9987
Amsterdam
Interesting....I'll look into this in more detail later....have to watch Holland-Germany now*smiley*
Cough :)
jbelanger
Member #: 831
Montreal, Canada
Paul,
Do you need the Aquamist controller or can you use the MS3 for that?
Jean
http://www.jbperf.com/
Jean, Is that a possibilty?
EDIT: Seems I can program one of the spare MS3X PWM outputs to drive a solenoid valve :) Just need to build a regulated water supply system.
Edited by Paul S on 13th Jun, 2012.
Water has been good on my supercharger setup, and that's with a home brew cheapo setup. Doesn't seem to use much water
I've just installed an older version of the Aquamist linked. Not really had a play yet, but (weather permitting) I'll be on the strip this weekend doing lots of fiddling.
jbelanger
Member #: 831
Montreal, Canada
Well, I haven't looked into it but there is a water injection feature in the 'advanced engine 2' menu.
Jean
