| Home > Help Needed / General Tech Chat > A-series Bench Setup. | |||||||
107 Posts Member #: 2556 Advanced Member Southport, Merseyside |
14th Jul, 2012 at 11:27:34am
14th Jul, 2012 at 11:30:48am
Swiftune have a dyno but it is expensive I seriously doubt it! |
14th Jul, 2012 at 11:32:43am
SC might be able to help, but a bit far from you.
14th Jul, 2012 at 11:37:17am
Who is SC?
14th Jul, 2012 at 11:43:23am
why not try putting an add on shipley to find somebody to transport the whole car to the rollers for you.
Edited by apbellamy on 14th Jul, 2012. On 11th Feb, 2015 robert said:
14th Jul, 2012 at 11:48:58am
Specialist components,
14th Jul, 2012 at 11:51:46am
Yeh, i see your point. The only thing putting me off doing this is that minisport do not deal with turbo's and im not sure who the closest rolling road are who deal with turbo's. Does anyone have any suggestions for rolling roads in the north west??? |
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
14th Jul, 2012 at 04:24:44pm
Since when did Minisport stop dealing with turbos? I know a few who have used then recently. Class C 3rd Place Avon 2011 14.18 @101mph |
14th Jul, 2012 at 07:56:25pm
Yes the guy at minisport is suposed to be vey good on the rollers.
14th Jul, 2012 at 08:24:29pm
If it's not road worthy how do you know it misfires under load?
14th Jul, 2012 at 08:38:36pm
And isn't getting it tailored somewhere a lot easier than removing the engine and refitting?
In the 13's at last!.. Just |
14th Jul, 2012 at 08:41:03pm
Compression check is the first thing I'd do, then check ignition and ignition timing. That'll tell you enough about the engine to tell you if there's a problem or it needs tuning. On 26th Jan, 2012 Tom Fenton said:
15th Jul, 2012 at 04:10:31pm
I was told recently by a friend that minisport wouldn't touch the turbo A series, maybe he was wrong, i will be giving them a call tomorrow to confirm.
15th Jul, 2012 at 04:29:56pm
right a few things to check. It seems that your fuel pressure is not risng as boot comes on. First lesson - the fuel presure regulator does not have any affect on the fuel pressure in the float bowl. It's only job is to raise the fuel pressure above that of the float bowl to make sure it keeps getting filled.
15th Jul, 2012 at 04:51:35pm
check you have dash pot oil in. On 11th Feb, 2015 robert said:
15th Jul, 2012 at 04:56:53pm
A simple test, hook up a pressure gauge to the fuel line between reg and carb. Then hook up some kind of compressed air (even a bike pump will do) to the line from plenum to reg. As you put pressure to the line from plenum to reg you should see the fuel pressure increasing. If you don't then there is a problem straight away. Edited by Tom Fenton on 15th Jul, 2012.
15th Jul, 2012 at 04:59:30pm
On 15th Jul, 2012 Tom Fenton said:
A simple test, hook up a pressure gauge to the fuel line between reg and carb. Then hook up some kind of compressed air (even a bike pump will do) to the line from plenum to reg. As you put pressure to the line from plenum to reg you should see the fuel pressure increasing. If you don't then there is a problem straight away. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
15th Jul, 2012 at 05:01:40pm
It will tell you that the fuel pressure is rising as it should when pressure is applied to the reg. At the moment the OP doesn't seem to know.
15th Jul, 2012 at 05:32:10pm
Rob Selby
15th Jul, 2012 at 06:07:46pm
Might just be just because I'm looking at this on my phone, but some of this plumbing looks squiffy to me?
15th Jul, 2012 at 07:17:52pm
It will tell you that the fuel pressure is rising as it should when pressure is applied to the reg. At the moment the OP doesn't seem to know. To me its a pretty standard starting point for fault finding a misfire onto boost. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
15th Jul, 2012 at 08:02:27pm
Well fucking shoot me for trying to help.
224 Posts Member #: 9987 Senior Member Amsterdam |
15th Jul, 2012 at 09:30:07pm
2 year old fuel??
337 Posts Member #: 9138 Senior Member wolves |
15th Jul, 2012 at 09:51:40pm
looks like midrange pipe goes off down the back of the engine some where |
16th Jul, 2012 at 06:53:33am
Sorry Tom, Just bugs me that the FPR gets blamed when it rarely is.
Edited by wil_h on 16th Jul, 2012. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
