| Home > Help Needed / General Tech Chat > Hard starting from hot. | |||||||
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
7th Oct, 2012 at 08:06:28am
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
7th Oct, 2012 at 08:26:43am
It's normal dude, just have to live with it On 20th Oct, 2015 Tom Fenton said:
7th Oct, 2012 at 08:36:32am
Yep they all do it, Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
7th Oct, 2012 at 08:58:56am
A heat shield would help
In the 13's at last!.. Just |
7th Oct, 2012 at 09:04:21am
its the one thing that annoys me about my turbo 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
7th Oct, 2012 at 09:06:33am
Side mount? In the 13's at last!.. Just |
7th Oct, 2012 at 09:11:36am
Thanks for the help guys, its so embarrassing sat outside tesco for 20 minutes cranking it over with people staring / smirking. Didn't realise they all do it. Hasn't anyone found a cause? On 25th Sep, 2009 mini13 said:
7th Oct, 2012 at 09:20:31am
The cause is, as you say, the hot turbo beneath, heating the fuel in the carb till it evaporates.
7th Oct, 2012 at 10:18:17am
The metro had a vent valve from the float chamber that opened to atmosphere when the ignition is turned off, I suspect for this very reason of poor hot starting. The Metro Turbo owners manual does advise that you should put the accelerator to the floor when hot starting.
7th Oct, 2012 at 10:24:05am
we used the switch the pump off on the van for a few seconds before shutdown to drain the float chamber. If something is worth doing, it's worth doing half of. |
7th Oct, 2012 at 10:35:00am
if your going to use the car on the road its definately worth adding the headsheild, and maybe a small 12v fan connected via a temperature switch. On 28th Aug, 2011 Kean said:
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
7th Oct, 2012 at 12:39:18pm
I wasn't aware of this issue, however my engine came with the throttle linkage plate (that goes between the carb and the spacer) bent to go under the carb like this:
Edited by Craigie-B on 7th Oct, 2012. On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
7th Oct, 2012 at 01:07:55pm
Possibly related to your issue as well, the SPi fuel pump isn't up to the job of any even lightly demanding turbo setup.
7th Oct, 2012 at 02:39:31pm
If you get the car hot take the dash pot off and wait a little it become obvious what the cause is (well did to me) the heat from the manifold and turbo heats the fuel chamber on the carb boiling the fuel off... now for boosted use we block the vent off so this fuel only has one place to go... out the jet in to the inlet manifold where it collects
Yes i moved to the darkside |
7th Oct, 2012 at 04:18:27pm
IMO it should never happen unless you have been driving the car hard and then stopped.
7th Oct, 2012 at 04:22:10pm
That's the van! The heat shield was read when we got it and had been repaired. If something is worth doing, it's worth doing half of. |
7th Oct, 2012 at 04:27:46pm
Another google pic
Edited by stevieturbo on 7th Oct, 2012. 9.85 @ 145mph
7th Oct, 2012 at 07:23:35pm
May be for another reason, but my hot starting problems with the T3 disappeared immediately after I fitted the GT17. |
7th Oct, 2012 at 07:30:49pm
On 7th Oct, 2012 tadge44 said:
May be for another reason, but my hot starting problems with the T3 disappeared immediately after I fitted the GT17. What manifold did you use ? How far is the turbine and manifold from the carb ? Maybe the smaller unit is just leaving more space for air to circulate, or it isnt running quite as hot ? 9.85 @ 145mph
7th Oct, 2012 at 08:30:47pm
Flol at "silly piece of bent metal"
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
7th Oct, 2012 at 10:19:21pm
Using a none bi-metallic jet holder in the carb don“t help with the hot start?
Pedro Silva
8th Oct, 2012 at 06:02:24am
Stevie, same manifolds but there is a lot more chance for air to get round the GT17 with it being smaller.
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
10th Oct, 2012 at 08:21:17pm
After a good run with my car after being switched off for about 15 minutes the car would need half throttle and spinning over a few times before it would start, but starts great at all other times, as Steve says its the heat from the turbo.. Main Build
10th Oct, 2012 at 08:33:44pm
A small motorbike cooling fan suitably placed to circulate air around the carb, or to try and blow the heat away from it might make a good difference. There are plenty on egay etc.
10th Oct, 2012 at 08:58:39pm
To be honest Steve, hasn't been that bad to start really, you just notice that difference when the car is hot, but the fan idea may be something to look into at a later date, got more pressing things to do on the car first as you know, will be over to see you shortly.. Alan Main Build
