| Home > Help Needed / General Tech Chat > Fully floating pistons | |||||||
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
6th Nov, 2012 at 09:50:15pm
Alright folks, bought some new forged pistons of a guy whos changed his plans... theyre fully floating, all im missing is the gudgeon pin circlips, any idea where i could get some of these?
6th Nov, 2012 at 09:54:21pm
Minispeed sell them I believe, so they will be the best bet.
6th Nov, 2012 at 09:54:53pm
6th Nov, 2012 at 09:57:41pm
Am i correct thinking ptfe buttons just push on the side of the gudgeon pin then the cylinder bore keeps the pin in? i've never heard anything of them before to be honest Edited by dev 11 on 6th Nov, 2012. |
6th Nov, 2012 at 10:00:41pm
6th Nov, 2012 at 10:03:40pm
On 6th Nov, 2012 Vegard said:
I'd get the circlips if you can! will be trying tomorrow :) |
6th Nov, 2012 at 10:28:23pm
I'd get the circlips if you can! I run a supercharger and I don't care the TB is on the wrong side.
6th Nov, 2012 at 10:32:49pm
Proper circlips don't do that. You'd think they were designed to stay where they are designed to be, no? On 13th Jul, 2012 Ben H said:
6th Nov, 2012 at 10:45:33pm
I understand what your saying, reading Des Hammill's book at the mo, the full circle clip looks the most reliable, the normal style that pinch in seem to wear a fair amount, good old Des says if you can turn them easily in the recess they should be replaced. He also says you should use the minimum distortion to install them. They seem a bit fragile to me and as such im going for buttons.
Edited by gr4h4m on 6th Nov, 2012. I run a supercharger and I don't care the TB is on the wrong side.
389 Posts Member #: 9751 Senior Member Derbyshire |
6th Nov, 2012 at 10:46:36pm
All the race engines I built (550 bhp +) used circlips and floating pins and never had any come out, although they are a bastard to get in. I'd be trying to locate the clips if possible. |
6th Nov, 2012 at 10:46:53pm
i have buttons they work... and as far as im aware they cant fall out and make love to my beautiful cylinder walls Yes i moved to the darkside |
6th Nov, 2012 at 10:50:13pm
Also rpm seems to count for a lot with our old aseries... Under 6 k and not many people seem to have a failure, up the rpm and I think a few on here have had a set make a bid for freedom. Not sure about love Brett!!!!! I run a supercharger and I don't care the TB is on the wrong side.
6th Nov, 2012 at 11:04:29pm
On 6th Nov, 2012 gr4h4m said:
Not sure about love Brett!!!!! well it would certainly fuck it up
6th Nov, 2012 at 11:09:24pm
:) I run a supercharger and I don't care the TB is on the wrong side.
![]() 97 Posts Member #: 9237 Advanced Member Banbury |
7th Nov, 2012 at 01:33:31am
http://skeptic-quokka.blogspot.co.uk/2011/...on-buttons.html |
7th Nov, 2012 at 07:38:04am
I went to interference pins. I felt uneasy about the shape of the new teflon buttons on the Accralite piston pins, since the pins have a tapered core and were alot shorter than the last set of piston pins I used with the buttons. On 26th Oct, 2004 TurboDave16v said:
7th Nov, 2012 at 08:03:03am
Interesting link. But as with all gospel on the web, you take away what you want from it.
7th Nov, 2012 at 08:11:02am
I've been using the circlips that come with the latest Omega pistons. I cannot believe that these could possibly fall out at the revs we're using when properly installed. On 13th Jul, 2012 Ben H said:
7th Nov, 2012 at 09:02:17pm
All the pistons at work use spring clips, and they are a right fucker to get out and back in again. I mentioned about PTFE buttons, and no one has ever heard of a clip coming loose...maybe its a mini thing? lol https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Nov, 2012 at 09:15:34pm
Interesting Mr Des also mentions that you can put them in the wrong way around.
24th Nov, 2013 at 09:47:27pm
Has anyone used these 73mm Iasa pistons yet? Can they be used with circlips/floating pins, as that would be a definite advantage to my short stroke engine. On 7th Oct, 2010 5haneJ said:
24th Nov, 2013 at 10:05:24pm
I use iasa pistons at work, all of which are fully floating and using spring clips. I'd be amazed if they worked there way out. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
24th Nov, 2013 at 10:23:19pm
modern piston c clips, snap rings etc are miles ahead of the older style circlip in terms of retention, On 28th Aug, 2011 Kean said:
25th Nov, 2013 at 10:32:14am
ill be using the PTFE type on my build due to ease of assembly/dis assembly also id rather not risk buggering up my new bores..
Edited by Turbo This.. on 25th Nov, 2013. |
25th Nov, 2013 at 05:12:04pm
Minispeed just confirmed they are fully floating with circlips. I will confirm the reliability of the circlips in the future, but as joe points out, things improve with time (generally speaking) so I'm not too worried. On 7th Oct, 2010 5haneJ said:
