Home > Show Us Yours! > Nimbus (off to Le Mans in it)
Off to Le Mans in the Nimbus, so needs a bit of fettling
First thing to do was to move the steering wheel. The guy who built it put the steering wheel off centre, so a couple of new brackets and some fettling with the hole where the column comes in and it's in pretty much the right place.
Next I moved the wing mirrors. They were on the main part of the door and not much use and looked odd. Now moved up onto the window frames. These may vibrate a bit more, but I'll deal with that if it's problem.
Now it's onto the intercooler. There is no real airflow to the IC. Ideally I'd like to fit an charge cooler, but I don't have the time inclination or money. So my plan is to make a fiberglass cowel to get the air from the side intakes through the IC.
Looks like this now. for all those with eagle eyes, yest the plemdiumbob is off. But an internal inspection revealed that it has the correct restrictor; home bodge job.
This is my basic shape in foam. a bit of sanding and smoothing and the addition of an inlet or two to go.
wng691s clubby
Member #: 9252
Cleethorpes
looks good. my boss is taking a tr2 to the le mans
Done now needs redoing lol
Cool!
What are the plans for the intercooler? duct those two pipes from the righthand duct into that box?
any plans to make a box to go below and run to a low pressure point at the back of the car?
Interesting plendulumnumunumununm.
Just concentrating on getting air to the IC at the moment, exit ducting would be more involved. At the moment, it may as well have no IC as it has no air through hit.
Interesting Is that the tie rod poking out under the throttle pedal?
what a brilliant vehicle .never seen one before .
This is quite a cool little car - interesting shape.
Yes it is. The front suspension is Viva.
Had it a few years actually. It's full GRP tub, only 20 tubs ever made. I have this as a complete car and Ben has a shell with suspension, but he's going to get rid of it.
Don't say things like that. Your plastic mini fetish is starting to rub of on me...
Hopefully they wont let you back into the country with this
supermotolee
Member #: 2153
kings langley
It's a bit Porsche 914 ish ISH
i like the layout of the car but why do they make the plastic cars so damn ugly
RS200 style intercooler? :)
Hoowwwww Dareeee Yoooooo!
Looks better in the flesh.
I did at one point consider this, but sensibly changed my mind.
I don't understand this. Typo? It should be stupidly? *wink*
A bit more progress.
First make a mould using high density foam.
Then lay it all up and remove the mould
Jobs a good one. Needs tidying and painting of course. Should make the IC of some use though.
fingers crossed that does the trick!
Looks good.
nick1275
Member #: 1615
Ferndown, Dorset
looking good.
which site are you staying on?
im going so will keep an eye out
On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy
On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind.
Not sure of site, find out when I get tickets.
Whatever it does, it'll be an improvement.
looks good.
Yo-Han
Member #: 3228
North of the Netherlands
Nice fabrication skills.
Dazed and Confused....
Looking forward to your race will, I am all ears and eyes
Is the fibreglassing as straight forward as it looks?
