Home > General Chat > should i sell :?
charlieb150
Member #: 9931
brighton
hi all ive just run in my new engine and it just started pumping out blue smoke, but the valve guides are good new stem seals, new forged omegas alll new bearings and well yeah cant really be bothered with rebuilding it again lol and dont really have the money
not the turbo is it? check the intercooler pipes for oil.
also check the plugs, it might just be getting into the turbine.
also whats the oil pressure? can you trust the gauge?
charlieb150
Member #: 9931
brighton
intercooler pipes are dry the oil pressure is now with 20w50 in it 50psi cold idle 35 warm and not sure its just a tim one
thanks charlie
Ben H
Member #: 184
Melton Mowbray, Pie Country
you will probably regret selling it. We have all been there and it is very demotivating. Just get stuck in and solve the problem then start enjoying the car properly. Half the fun is learning and fixing.
Is the turbo drain clear?
http://www.twin-turbo.co.uk
charlieb150
Member #: 9931
brighton
im not to sure ill take that of tomorow and have a look but its my everyday car lol it seem to be smoking more on overrun than on boost
Don't sell. Pack it away if your not into it at the moment and drag it back out when the motivation is back
madonminis
Member #: 9371
East Yorkshire
Too nice to sell. Get a cheap car for daily use if needs be
If its smoking on over run, it could be the valve guides?
Also, even on a new head the guide seals can pop off from boost pressure,
woth pulling the rocker cover and giving the seals a poke with a small screw driver to see if they are still seated, also the std rubber ones can cook, you want the brown viton MPI ones.
kappa
Member #: 9854
Hounslow, Middlesex
What colour is this mate, as I have a 71' clubby estate and going to turbo the car. Just wanted to find out is this Old English White
charlieb150
Member #: 9931
brighton
kappa to be honest i have no idea lol i painted the engine bay ford frozen white but the rest of the car is off white im not sure how do i find out
Jawd
Member #: 10212
Sleaford Lincolnshire
Hi Charlie.
Your car looks the dogs mate, I would try running the oil a little lower on the dipstick to see if it improves things at all first,
Will it smoke everytime you slow down or only from high engine speed?
Check stem seals as suggested above also
Just had similar issues with my engine. too the whole thing apart, new rings, stem seals etc. and it still smoked.
Last week I bought a turbo re-build kit, in 3 hours I removed the turbo, took it to bits, rebuilt it and stuck it back on. Now no smoke.
Smoked on overrun and at idle, was a little intermittent.
Lovely car by the way (except the odd front wing)
Jawd
Member #: 10212
Charlie,
From what Wil is suggesting it could be that you are forcing to much oil onto the turbo bearing although without looking at the sealing arrangement I have no idea, it would be something I would be checking as an engineer as we would presume to much oil would be as bad as not enough,
Just my thoughts mate hope u get it sorted tho
charlieb150
Member #: 9931
brighton
Right well at idle you don't really get much smoke but when I pull away just normal not booting it I get a little bit but if I boot it slow down then carry on it pumps out a fair bit lol( is it possible to have the turbo seals just go on the exhaust side ? )
Jawd
Member #: 10212
Charlie,
Have you fitted a new/high capacity oil pump?
If so I would adjust my oil pressure to see if made a difference.If it did then I would have the turbo rebuilt.
Also you need to chat with someone that knows the turbo your running inside out to be certain
Turbo seals can go on just the zorst side. Wintersurfers car has been like this since we built it. Tight git.
You will regret selling it.
charlieb150
Member #: 9931
brighton
Oh I'm running a t3
mcalvert39
Member #: 442
Manchester
Sounds like turbo seals.
Dont get rid. You've done the hardest part and got it back on the road. These are just teething problems. Typical mini IMO turbo'd or not.
Ah I saw this the other week and I was wondering who's it was
Nice car, just tuck it away for a while and all will be fine
Edited by Nic on 6th Jan, 2013.
charlieb150
Member #: 9931
brighton
Jawd it doe it from both low and high but I notice it more at low - Also what's it like to rebuild a t3 price and time thanks charlie
The T3 is a piece of piss to rebuild. There's some good guides online.
charlieb150
Member #: 9931
brighton
Ok thanks any idea of where to buy a good kit
welshdan
Member #: 1111
s wales
Thete is someone selling a 360 thrust kit on ebay on sale until tomortow. Ordered one yest.
charlieb150
Member #: 9931
brighton
Could you pm me the number please thanks
