Home > General Chat > Minispares selector bias barrel and KAD quickshift
Both at the same time?
Yay3 Votes 3 Votes - 60%
Nay2 Votes 2 Votes - 40%
Has anyone. Used one?
tough one that. I have a bias spring and quick shift in the hillclimber. It's great, but I prefer a longer throw on a daily. Bias springs are good though.
I was told by mini spares that it's not really needed.
hmmm. Had comedy throw on my gear box, so put the quickshift on, thought I would try the bias whatsit too.
Third is stiff, but with the bias thing tightened on the shaft I can't really get anything other than 4th...
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have one too on the kad quick shift. I found that if you put it on as instructed it was too stiff. But rotate it round a bit and it is much better.
http://www.twin-turbo.co.uk
dev 11
Member #: 9393
stoke on trent
Anyone got a picture of one fitted?
Star Mag
Member #: 375
Leicestershire
I have the bias spring with a cut down gearstick and its excellent.
shellspeed
Member #: 9580
Surrey
Never got mine to work and took it off in the end however I do think it had more to do with the shift being worn out. Lesson of the day would be make sure the gear change is not worn before fitting.
I'll have another fiddle when I get chance. My shifted seems in good condition.
shellspeed
Member #: 9580
Surrey
Had to get a new bush made (were not available) in the end. By the time I sorted it I had sold the spring on ebay.
Ben H
Member #: 184
It is maybe also worth mentioning that stiing in my garage, going brum brum, and changing gear is quite difficult with the spring. But ones driving properly it works very well.
Hmmm. I think I will leave it fitted and worry about it once the car is on the road. After all, i fucking hate getting roll pins out of the selector rods with the car on the stands...
nala56
Member #: 9661
Sheffield South Yorkshire GB.
This my standard gear change, used it on 5 speed and 4 speed box, its a lot nicer to drive with it
fitted, but I think mini spares state that its not for a quick shift, sat now waiting for me to finish my
rebuilt engine..
Main Build
Upgrade to Turbo
Alan - going on the instructions with mine, you have yours on back to front.
nala56
Member #: 9661
ok Andy will change it before I fit it to the car, thanks..
Edited by nala56 on 6th Mar, 2013.
Main Build
Upgrade to Turbo
nala56
Member #: 9661
shows it being right on this from mini spares Andy..
Main Build
Upgrade to Turbo
Slide the bias barrel onto the rod, spring facing the back of the car.
http://www.minispares.com/article/Technica...85-3c666316444b
nala56
Member #: 9661
Yes your right Mate, not had instructions for a long time for mine, had the dam thing for 2 years now been fitted
wrong all that time, should have known not to doubt you, It does look as though its right looking at that
drawing dont you think?..
Main Build
Upgrade to Turbo
Indeed. It probably make fook all difference either...
nala56
Member #: 9661
Funny part about it all is I have overhauled this gear shift so had it all apart, rebushed, new shaft, new center yoke and still put it back the wrong way round, no hope for me Andy..
Main Build
Upgrade to Turbo
Ben H
Member #: 184
It makes no difference which way round it is. It is more important to get it in the right position on the shaft. I had mine to far forward and could not get second gear as it clashed with the other rod.
I think I have the collar for the quick shift slightly of straight which won't be helping.
Where abouts is your's sat Ben? Mine ends up with the spring somewhere near the steering rack.
Ben H
Member #: 184
I can't remember exactly, but I know when I got it wrong it clashed. So I had to move it to a more central position between the fork and the bend.
nala56
Member #: 9661
Ill be putting my engine back in shortly and I do mine with aid of a jig on wheels, and have got flip front, so before I put engine and sub frame back to the car ill take a photo of it setup, doing it this way its easy to setup gear shift no rolling about underneath the car..
Main Build
Upgrade to Turbo
