| Home > Technical Chat > BMW K1200RS - Possible supercharger conversion | |||||||
![]() 218 Posts Member #: 9213 Senior Member Scotland |
17th Sep, 2013 at 01:35:30pm
Hi guys,
17th Sep, 2013 at 01:55:51pm
Good questions,
17th Sep, 2013 at 02:10:50pm
On 17th Sep, 2013 Joe C said:
Good questions, yes a 1380 can be turbo'd/supercharged, the bore flex issue seems to be largely an old wives tale. You will need to get the CR down, i would aim for 9:1 for an engine with about 12psi of boost. it is possible to machine piston dishes bigger, but obviously there is a limit, also the head chamber cak be taken out a bit too... you'll need to do some measuring and some calculations. You will need to double check the class rules, but there will be a multiplier added to the capacity... thanks for the info. Forced induction requires a 1.4 multiplier, so would still be within 2000cc which is the next class up. currently in modified up to 1400cc |
17th Sep, 2013 at 02:32:31pm
I seem to remember somthing about ending u in Pro mod class for hill climbing....
17th Sep, 2013 at 03:41:03pm
It is not currently legal to race a mini in upto 2000, but will be next year.
http://www.twin-turbo.co.uk
17th Sep, 2013 at 07:53:57pm
i was planning to supercharge but the cost of doing it properly. i.e a rotrex charger has led me down the turbo route. but really depends how much your prepared to spend. that said the dyno graph from one of sc's supercharged engines is impressiv
17th Sep, 2013 at 07:55:11pm
Personal I'm not a fan of 1380 setup cause it don't leave room for over bore in future
17th Sep, 2013 at 08:18:05pm
1380s do make good power |
17th Sep, 2013 at 08:41:43pm
If you haven't already bored it, I wouldn't bother going any more than 1293 on a standard block, I really don't think there is any real gain going 1380 over 1293 on a blown engine. A 1380 with an SA stroked crank on the other hand would make for a revy engine! :)
224 Posts Member #: 9987 Senior Member Amsterdam |
18th Sep, 2013 at 06:46:37am
Since you are already competitive in the next class, it seems you don't necessarily need 200+HP and are just looking to make your mini a bit more 'fun' to drive. A low boost supercharged set up would easily achieve that without the need for steel cranks, intercooling, or compression drops. Go for a Lysholm type or Rotrex supercharger (SC do a nice kit) as they are much more efficient than the eaton type pumps that just create massive amounts of heat.
18th Sep, 2013 at 07:24:02am
Only thing with the supercharger gear it will add weight, so it needs to add enough power to offset that. If something is worth doing, it's worth doing half of. |
18th Sep, 2013 at 08:27:12am
thanks for the replies guys, very useful!
30th Sep, 2013 at 08:54:57pm
Is this the regulation change you are referring to:
30th Sep, 2013 at 09:07:25pm
i have found the search function and doing lots of reading! |
15th Oct, 2013 at 11:54:22am
So, after lots and lots of reading. I think i'm going to go down the turbo route. Aiming for around the 200bhp mark. I've been reading about turbos but im really none the wiser or closer to making a decision. The GT28RS looks a bit overkill for what im after, the Gt17 maybe a bit small, so Gt20 or 25 about right?? Does anyone run twin scroll? I'm not interested in a peak figure but something that has decent throttle response and not too much lag!
15th Oct, 2013 at 03:38:38pm
Have a look at the build threads for madmk1 and Nic. They both have huge side mounted intercoolers that work well with a rad at the front.
In the 13's at last!.. Just |
15th Oct, 2013 at 06:50:45pm
Getting the compression down will be a real challenge. What pistons are in there and what is the piston to deck height? On 7th Oct, 2010 5haneJ said:
15th Oct, 2013 at 07:09:44pm
will go through those threads, thanks.
20th Jan, 2014 at 02:19:06pm
Looking to machine the pistons down, so that i can up the CR.
20th Jan, 2014 at 04:14:32pm
John Kimmins built a very nice rotrex suprcharged 16v
20th Jan, 2014 at 08:09:40pm
Specialist components also do their gasket in varying thicknesses up to 6cc if that is required.
20th Jan, 2014 at 09:56:34pm
Yes, the SC supercharger kits are what got me thinking about forced induction. However, it appears that there is much more choice and availability in the turbo market, that can also be had for very little outlay.
Edited by nky_84 on 20th Jan, 2014. |
28th Jan, 2014 at 01:32:52pm
Initial manifold mockup and turbo placement:
28th Jan, 2014 at 05:41:07pm
Jimsters manifold is kind of like this, but probably shorter runners, as the turbo's down the back off the block,
28th Jan, 2014 at 06:03:31pm
I made my runners as short as possible, to try to reduce lag as much as possible. Also wanted to keep things simple. As has been said 250bhp is going to be easy with a turbo, and it WILL be a handful in a 550kg mini. I had to move from 7" Avon's to 9" to get traction, and still find traction control handy when coming out of bends. Team www.sheepspeed.com Racing
