| Home > General Chat > MED making BMW K kits and parts | |||||||
![]() 218 Posts Member #: 9213 Senior Member Scotland |
11th Mar, 2014 at 10:12:37pm
Noticed today that MED are busy developing kits and associated parts for twincams |
![]() 324 Posts Member #: 9441 Senior Member South Devon |
11th Mar, 2014 at 11:03:42pm
They've probably had a customer ask them to build a K head engine and are just incorporating the parts they've made into they're range. |
12th Mar, 2014 at 08:19:26am
looks good might be able to get me a k1100rs engine with blown clutch basket/houseing not that ill use it any thime soon but if i get the optuilty and its free/cheep i cant say no |
9 Posts Member #: 10740 Junior Member B48 |
12th Mar, 2014 at 10:25:49am
In the first link there are 5 heads, looks like more than a one off customer? |
12th Mar, 2014 at 10:39:59am
Interesting.....
12th Mar, 2014 at 10:46:23am
I seen "Steel block" what do they mean? I thought all A series where cast Iron |
12th Mar, 2014 at 11:16:48am
"1460cc steel engine" probably means all the internals, crank, rods, main caps etc not the block. |
12th Mar, 2014 at 01:02:57pm
Throttle bodies look familiar and I suspect you'll find other parts will be too.............. On 26th Oct, 2004 TurboDave16v said:
12th Mar, 2014 at 03:51:02pm
On 12th Mar, 2014 Sprocket said:
Throttle bodies look familiar and I suspect you'll find other parts will be too.............. Where are the TBs from then? They aren't the SC ones... On 17th Nov, 2014 Tom Fenton said:
12th Mar, 2014 at 04:18:06pm
Those look like the S.C. 7 port throttles to me On 26th Oct, 2004 TurboDave16v said:
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
12th Mar, 2014 at 06:44:05pm
They are made by AT Power, supplied by both SC & MED. Med have been using AT Power for their 7 Port for a few years. SC seem to have gone to a different supplier for their new 7 port TB's and SPI setup though. Not sure why.
Edited by alaskanow0 on 12th Mar, 2014. Class C 3rd Place Avon 2011 14.18 @101mph |
14th Mar, 2014 at 05:51:44am
I take your point with the head gasket but £120, surely you could get one made yourself for a lot less |
14th Mar, 2014 at 10:26:48am
On 14th Mar, 2014 philc said:
I take your point with the head gasket but £120, surely you could get one made yourself for a lot less Where would you get that done,what sort of cost saving and turn around? |
14th Mar, 2014 at 11:06:36am
Instead, just make yourself a template so you can convert a BK450 to the K-stud spacing in a few minutes with a drill / dremel On 17th Nov, 2014 Tom Fenton said:
14th Mar, 2014 at 11:59:08am
i see, makes sense. Anyone know what thickness the BK450? Also, seems too good to be true. I've always gone with expensive head gaskets and never had a problem, but for £100 saving, its perhaps worth the risk..... |
14th Mar, 2014 at 12:44:25pm
The most powerful & quickest proven K1100 motor on this site uses a BK450, so it's proven.
14th Mar, 2014 at 03:12:27pm
On 14th Mar, 2014 Turbo Phil said:
The most powerful & quickest proven K1100 motor on this site uses a BK450, so it's proven. Phil. and most powerfull 5 port as well as 7 port lets not forget unless im mistaken so is the most powerfull 998
Yes i moved to the darkside |
14th Mar, 2014 at 03:46:52pm
The most powerful & quickest proven K1100 motor on this site uses a BK450, so it's proven. Phil. Who has that title? Whats the spec and power output of the car? |
14th Mar, 2014 at 03:50:09pm
that would be jimster, it was 260+ bhp i think its just had a make over Edited by Brett on 14th Mar, 2014. Yes i moved to the darkside |
14th Mar, 2014 at 07:47:58pm
14th Mar, 2014 at 08:47:47pm
thats quite impressive anyone know the weight of jims car? at a guess that thing makes like 400 hp per tone |
14th Mar, 2014 at 09:09:02pm
http://www.youtube.com/watch?v=SyFlhYnS4G4...HRDdmBr_w3ZvXZA On 26th Oct, 2004 TurboDave16v said:
976 Posts Member #: 3228 Post Whore North of the Netherlands |
15th Mar, 2014 at 07:20:09am
This is my favourite:
Dazed and Confused.... |
15th Mar, 2014 at 08:25:00am
15th Mar, 2014 at 01:05:06pm
I totally agree!!! That should be the inspiration for any turbo mini owner asking if it's worth it....
. Bit late to the party but very interested to see what they come up with. Already seem to me making Pistons, valves, head studs, throttle bodies, gaskets and their kits are in development....
