| Home > Help Needed / General Tech Chat > Can select gears but cant get drive! | |||||||
![]() 537 Posts Member #: 8926 Post Whore Sheffield |
11th Apr, 2014 at 10:42:29pm
I can select all gears but cant get any drive (turning wheels while jacked up).
11th Apr, 2014 at 11:33:53pm
Put the car in gear and see if it will turn the engine over, obvious check but it's a basic start.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
![]() 130 Posts Member #: 9395 Advanced Member |
12th Apr, 2014 at 12:25:47am
If while on the jack, make sure one wheel is on the ground while turning the other by hand
12th Apr, 2014 at 06:05:01am
Going to go put the car back on the ground a try again now. |
12th Apr, 2014 at 06:40:48am
Is this a fresh build? Could be lots of things, but if so I reckon it'll be something pretty fundamental such as flywheel loose, idler gear missing, clutch plate missing, final drive pinion missing etc etc |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
12th Apr, 2014 at 06:52:36am
Hopefully its something simple Nick.
12th Apr, 2014 at 08:40:01am
I would be inclined to leave the engine off, put it in 4th gear, push the car and see if this turns the engine over. This will cause less damage if (for instance) the flywheel is spinning on the crank. In the 13's at last!.. Just |
12th Apr, 2014 at 08:59:39am
I assume you have started the mini ? so cant see the flywheel spinning on the crank.
On 12th Apr, 2014 theoneeyedlizard said:
I would be inclined to leave the engine off, put it in 4th gear, push the car and see if this turns the engine over. This will cause less damage if (for instance) the flywheel is spinning on the crank. Edited by lee.pb on 12th Apr, 2014. What the mind can conceive the mini can achieve
12th Apr, 2014 at 09:01:48am
Forgot to fit the idler gear? I cant think of anything other than the flywheel which isnt doweled or keyed so it would provide(some) drive even if it was loose. turbo 16v k-series 11.9@118.9 :)
12th Apr, 2014 at 09:16:07am
If you have installed the clutch plunger wrong it can hold the clutch disengaged all the time. Take the wok off sprag the engine in place with a lump of wood and try again see if you then have drive .
12th Apr, 2014 at 09:35:46am
Is this a pre verto clutch?
Yes i moved to the darkside |
12th Apr, 2014 at 09:52:48am
first up id back the adjustment bolt right out till its not touching anything as if that is to far out it will hold your clutch open been there but mine still had some drive just slipped when accelerating tho
12th Apr, 2014 at 09:53:37am
Clutch plate the wrong way round? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
12th Apr, 2014 at 09:58:38am
On 12th Apr, 2014 Nick warwick said:
Going to go put the car back on the ground a try again now. My money is on the the diff free wheeling as there is no resistance from the wheels as it's in the air. On 11th Feb, 2015 robert said:
12th Apr, 2014 at 10:02:08am
Is this a wrlondon engine ?
12th Apr, 2014 at 10:40:42am
i dont understand how that could work?
Going to go put the car back on the ground a try again now. My money is on the the diff free wheeling as there is no resistance from the wheels as it's in the air. |
12th Apr, 2014 at 10:50:58am
Try it yourself. If you jack the front of the car up and turn one wheel it just goes round without turning the diff. This is why minis wheel spin the left wheel and leave the right wheel pretty much stationary. On 11th Feb, 2015 robert said:
12th Apr, 2014 at 11:58:09am
BINGO!! It was late haha needed sleep!
12th Apr, 2014 at 12:05:55pm
So what was the problem?
12th Apr, 2014 at 12:10:53pm
sounds like you have the MJ on a circuit that gets cut when cranking On 11th Feb, 2015 robert said:
12th Apr, 2014 at 12:16:01pm
You need a live that doesn't drop out on cranking but you already know this.
12th Apr, 2014 at 02:36:48pm
12th Apr, 2014 at 02:47:50pm
You should be taking feed from second ignition click, thick white wire coming from the ignition barrel. On 26th Jan, 2012 Tom Fenton said:
12th Apr, 2014 at 03:13:09pm
On 12th Apr, 2014 Carlzilla said:
You should be taking feed from second ignition click, thick white wire coming from the ignition barrel. But not directly from the ignition switch and it's wiring. 2 minutes with the multimeter will tell you which fuse will do what you need. On 11th Feb, 2015 robert said:
12th Apr, 2014 at 03:15:50pm
I don't have a multi meter guys |
