Home > Technical Chat > Thoughts on KAD rear discs
alaskanow0
Member #: 8466
Mansfield
What's people's opinions on the KAD rear disc conversation. I've heard a few issues with the hand brake not working as it should.
My current drum setup is 4.2kg, these will save me another 1.4kg each side.
They was a pig to set up but now they are fine as they are playing ball.
alaskanow0
Member #: 8466
Mansfield
What problems setting up. Handbrake or normal brakes. I'm thinking of losing the handbrake for a line lock anyway.
I wouldnt bother,
I put a set on thinking they would be less hassle than adjusting drums, but they kept draging and burning out pads.
stuck them on ebay and stuck minifins and alloy hubs on.
Chalkie
Member #: 9764
Northamptonshire.
Can't someone make ally back plates?
I'll have a look into making a set of these to see how they work, I was thinking of making alloy slave cylinders, this could work well with it. What kind of money would people pay for ally back plates, cylinders and adjuster mechanism?
I would defo have a set of slave cylinders the issue is the sizes people might want? I use the 1275 gt version that I'm not sure many people use.
Oh and removing the circlip and using a nut and anti vibration washer would be great!
alaskanow0
Member #: 8466
Mansfield
Sounds like a good plan. I'd be interested in a pair. They weigh 0.85kg each in steel.
D4VE
Member #: 10749
lowestoft suffolk
Id have a pair
Nothing gets past Dave lol
jonny f
Member #: 9894
Dorking
Be interested
I'm sure Ive seen alloy wheel cylinders on somthing that looked a similar size to mini ones.
I'd have a set.
Sounds like Jimbo has a plan lol.
I could be interested in back plates, had this thought a few months ago.
I've just purchased a set of these yesterday BTW:
http://www.wilwood.com/Calipers/CaliperLis...ydra-Mechanical
I can't find much info about them, so just figure I need a pair in my hands to get a better feel of them.
Edit - bad link, try this: http://www.ebay.com/itm/PAIR-WILWOOD-HYDRA...T-/271014679064
Edited by turbodave16v on 13th Aug, 2014.
clubbie70
Member #: 8935
netherlands
I'd have a set :)
Rammie2000
Member #: 10190
belgium
I would have a set. Defently like like the idea of loosing the circlip and using a nut on the pump.
1380rich
Member #: 9766
Warwickshire
I had problems with the handbrake seals leaking around the mech but when I told them I had a line lock they blanked the handbrake mech off and rebuilt for free as they had redesigned the seals since. A pain to set up but once eventually set they've been alright
Avon 2010 class c 3rd
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
Id be interested in some alu rea brakes in drum form mini fins backing plAte assembly
Id then need to convert to a beam to really take advantage
philc
Member #: 1346
bromsgrove
they seem a lot of money for not a lot of gain imo.
Price dependant, I'd also be very interested.
Any news on these Jim? I'd be interested in a lightweight drum setup too *smiley*
I'm pretty sure that there's a fair bit of weight to be saved on the hand brake linkages inside the drum if you replace them with drillium.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
just leave it in gear so long as the cylinders take a good while to leak down your good *hehe!*
