| Home > Help Needed / General Tech Chat > custom length braided hoses ??? | |||||||
4 Posts Member #: 604 Junior Member |
13th Aug, 2005 at 09:12:36pm
evening. |
13th Aug, 2005 at 11:02:36pm
I just had some oil cooler ones made at preston hydraulics.They had a display rack with pretty much everything on it.....loads of types of airfilter tube
14th Aug, 2005 at 09:51:59am
go to rally design, you can buy the braided hose and connections to make your own brake and fuel lines Team www.sheepspeed.com Racing
14th Aug, 2005 at 11:07:34am
www.minipart.co.uk
Edited by joeybaby83 on 14th Aug, 2005. "Turbo's make torque, and torque makes fun"
969 Posts Member #: 47 Post Whore Not very sunny swanage |
14th Aug, 2005 at 01:49:26pm
i would also try iain as i believ he deals with goodrich for all the pipes he gets for people on here, so if dt can get them there is a good chance he may be able to. he's off on his hols at the moement, but will be bcak next week sometime i think, drop him a pm. And on the 7th day........... God created turbochargers! |
16th Aug, 2005 at 09:55:39pm
Spectrum hoses in High wycombe, Bucks, I got all my intercooler hoses there.They can make up any braided hose you like and there quite reasonable
18th Aug, 2005 at 10:10:10pm
at the moment its looking like i need approx 4 or 5 meters of braided hose (with various couplings along the way)
18th Aug, 2005 at 10:57:21pm
i would say a hydraulic place my local place sort almost any type of pipe you can thimk of!! |
18th Aug, 2005 at 11:34:46pm
i was going to go the same route, but have decided to use copper pipes, running through the car now.
19th Aug, 2005 at 06:23:17am
On 18/08/2005 23:34:46 joeybaby83 said:
everyone i spoke to about it reckoned that with a fully braided system, the brakes feel spongy and vague...?? From my personal experience that is bollocks. My track car is fitted with a bias pedal box and aeroquip lines all the way from the master cylinders to the brake calipers. The brake pedal is akin to standing on a brick, e.g. it hardly moves. The harder you press, the harder it stops. It certainly is not spongy or vague.
19th Aug, 2005 at 02:34:40pm
everyone i spoke to about it reckoned that with a fully braided system, the brakes feel spongy and vague...?? My Mini runs braided pipes throughout, as does the miglias I've seen. my brakes are fantastic Team www.sheepspeed.com Racing
19th Aug, 2005 at 03:06:06pm
What's the advantage of braded pipes throughout?
19th Aug, 2005 at 03:29:42pm
I'm just plain lazy, and it's easier to run, Team www.sheepspeed.com Racing
19th Aug, 2005 at 03:33:34pm
So it's just for show then.
19th Aug, 2005 at 03:37:41pm
I would have done, but would have only had tom fenton and dave c giving me abuse and calling me a chav Team www.sheepspeed.com Racing
20th Aug, 2005 at 12:30:53am
you also need to be a big spedner to run it through out, where as copper will cost you £4 or so |
20th Aug, 2005 at 12:35:26am
Yes. I'll vouch for that, the aeroquip is expensive, as are all the fittings. I think I spent £180ish on aeroquip for my track car.........but the advantage, you only buy it once, and the ends are all re-useable.
20th Aug, 2005 at 01:24:52am
so is copper-you just keep cutting it shorter!! |
22nd Aug, 2005 at 12:30:10am
can someone explain how aeroquip lines fix onto things like carb connections etc which normally have a push on fit, i take it they do all thread sizes i need a front brake pipe made up any idea what size the connections are? |
22nd Aug, 2005 at 08:52:22am
No point using proper aeroquip on carb lines. Pressure no where near high enough to warrant it, the standard lines just stay on with PUSH on connections!
444 Posts Member #: 2885 Senior Member |
30th Nov, 2008 at 05:53:34pm
Minipart.co.uk does front to rear lines as well as every other line, i just bought a clutch master to slave hose with banjo ends, VERY high quality hose, stainless fittings (inc. banjo bolts) perfect fit and only £8!
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
30th Nov, 2008 at 08:32:45pm
We run all our hoses in the f1s in braided hose, and clutch lines. Wouldn't use it fully on a road car, fuel lines are serious overkill when copper fuel lines do the job just as well.
30th Nov, 2008 at 08:40:11pm
dont you need a real powerful hydraulic tool to crimp the ends on? |
30th Nov, 2008 at 10:12:07pm
it depends on the type of hose and fitting, the type we use have reusable fittings and can be made to any length. Some hoses have crimped ends, but we're a bit more low budget than that!! |
![]() 514 Posts Member #: 2104 Post Whore Essex - UK |
1st Dec, 2008 at 10:59:21am
these people supply all kinds of hose and hose fitting including braded oil/fuel lines, silicone hose as well. they hose will make hose to any length any fittings
Edited by turbominij on 1st Dec, 2008. "Tuning should be a compromise between what is possible and what is necessary"
