| Home > Help Needed / General Tech Chat > engine wont rev past 3k under load | |||||||
20 Posts Member #: 10623 Member Wrexham |
16th Apr, 2015 at 09:11:02am
When I'm driving I just can't get onto boost. Basic metro turbo engine running a megajolt.
16th Apr, 2015 at 09:25:07am
Do you have a wide and connected up? I run a supercharger and I don't care the TB is on the wrong side.
16th Apr, 2015 at 09:33:08am
Have you blocked the float chamber venting pipe on the carb ?
16th Apr, 2015 at 09:41:02am
Gr4h4m , no I don't have one.
16th Apr, 2015 at 11:48:59am
Could be that the fuel pressure is not rising as the boost comes on.
16th Apr, 2015 at 03:11:00pm
If you've blocked the venting pipe, deffo check the gasket Wils mentioned.
16th Apr, 2015 at 04:27:30pm
Sounds like you need to do the good old tee-piece trick...
16th Apr, 2015 at 06:03:55pm
Would this happen while driving, the problem just suddenly happened one day while I was over taking a car on the bypass. |
16th Apr, 2015 at 07:49:50pm
what about the pressure regulator? just thinking aloud but if the diaphragm has spli for instance, it wont be raising the fuel pressure as it comes on boost? |
16th Apr, 2015 at 07:57:42pm
Part throttle lean off pipe? In the 13's at last!.. Just |
17th Apr, 2015 at 10:33:57am
Not sure if this changes anything but now it won't rev past 3k even in neutral |
17th Apr, 2015 at 11:17:55am
Post a photo of your carb plumbing. Check the part throttle pipe for splits. In the 13's at last!.. Just |
17th Apr, 2015 at 11:30:05am
Fuel filter blocked? Fuel pump u/s?
17th Apr, 2015 at 06:24:51pm
Here's the plumbing for the carb |
18th Apr, 2015 at 02:53:51pm
To check the gasket it's the one after removing the plenum? |
18th Apr, 2015 at 03:27:54pm
Pluming looks right. If it was working before then it probably is.
18th Apr, 2015 at 04:07:49pm
Ignition is megajolt running the default map so should be fine in regards to that |
18th Apr, 2015 at 04:10:27pm
Plugs?
18th Apr, 2015 at 04:51:04pm
Boost signal to the MJ not working resulting in rubbish ignition advance? On 11th Feb, 2015 robert said:
18th Apr, 2015 at 05:29:12pm
Plugs are brand new, less than a week old and the signal from the megajolt seems spot on. |
18th Apr, 2015 at 05:29:52pm
Listen to Joe C and try a new set of the right heat range.
18th Apr, 2015 at 07:08:40pm
What range are you using tadge44 |
60 Posts Member #: 1066 Advanced Member germany |
19th Apr, 2015 at 06:15:11am
Long shot but..... Fitted a new rev counter?
19th Apr, 2015 at 08:17:56am
Check that the trigger wheel has not moved. They can slip and will always retard which is lucky. On 26th Oct, 2004 TurboDave16v said:
19th Apr, 2015 at 04:42:09pm
NGK 8,s are what I use. |
