Home > General Chat > RR friday!
mini300bhp
Member #: 653
Cambs
Im getting my mini RR on friday. I know 300bhp is out of the question (at the moment !!!), but hopfully it should push out over 200. Thats if the dizzy will allow it. Its an avonbar modded turbo dizzy, don't know if they are any good??? Anyone used one of these at high boost?
Any other things I need to check before the big day? Im asking because its my first turbo car, first car I built and the first car to have a RR tuneup.
Wish me luck! (BANG)
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
lanxter
Member #: 396
sheffield/rotherham
good luck mate hope all goes well 4 ya
speed is the best rush i have ever had!!!
add me lanxter@hotmail.com
giallofly
Member #: 164
The Stig..
Newport Pagnell
So what in breif has been done to this engine?
check and double check everything.
tyre pressures, cable ties to keep things neat, dashpot oil. full service if its done a fair bit of running etc etc.
A dizzy will run fine on as much power as you like. its just how the power comes in etc is how suited the dizzy is to the car.
common sense stuff.
adam1330
Member #: 238
essex
whos rollers are you going on?
As Iain says - the dizzy won't affect the peak power one bit.
If it's a mile off (which I doubt) then get them to write down the 'ideal' advance every 1000rpm measured straight off the TDC reference and #1 plug. It doesn't even matter how accurate the TDC reference is for this, the important thing is the change in advance every 1000rpm. With this info - you can send your dizzy off somewhere and have it optimised to suit your engine.
A few bottles of ready-mixed coolant is always a good idea - aswell as plenty of fuel. If you're running 'special' plugs like C57's, then take along at least one spare.
Set the rockers accurately, and make sure the sump plug is tight!
good advice in this thread.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Sump plug tight yes Dave...
Only a muppet would leave that loose only to fall out all over the rollers!
Edited by giallofly on 6th Sep, 2005.
mini300bhp
Member #: 653
Cambs
Thanks for the advice boys. I'll make sure everything is tight, especially the sump-plug!
Im going to mini-speeds rollers.
engine spec:
Metro Turbo Enging,
Bleed valve!
Thats about it I think.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Oh.. a comedian to!
Minispeed!
Edited by giallofly on 7th Sep, 2005.
mini300bhp
Member #: 653
Cambs
Only Joking.
Breif spec is
Engine:
1293cc offset bored
Forged pistons (11cc I think, not 18)
Mini Speed ultimate turbo cam
Belt Drive Timing belt
Arrow H section Steel Rods
EN40b Steel Crank
4 Bolt steel C-main Strap
Steel Head Gasket
ARP Head and Rod bolts
Interia Ultralight flywheel+backplate
Paddle plate
oil damper-pully
Oil Squirters
Full race turbo head, 12g940 casting, 36cc chaimbers,1.5 full roller rockers,bigger valves, cant remember size, 3 angle valve seats.
Ported manfolds, turbo+carb.
Standard T3 turbo (for now)
Box:
JKD 6 speed s/c Dog
1:1 roller Drops
3.9 diff ratio, semi helical
Quauif LSD
Comp crownwheel bolts
JKD Equal length drive shafts (steel)
Aldon coil
Thats about it I think. 200bhp should be possable I hope??
giallofly
Member #: 164
The Stig..
Newport Pagnell
Trick bottom end..........
You will struggle to do 200 on a standard turbo....
Banannas you must remember...
mini300bhp
Member #: 653
Cambs
What sort of turbo do you think would be best for most 'banannas'?
giallofly
Member #: 164
The Stig..
Newport Pagnell
a bigger AR on the ex side and a bigger trim on the compessor side...hybrid t3 IMO.
mini300bhp
Member #: 653
Cambs
Sounds expensive?
Best get to bed so I can get up early for some overtime!
What turbo builders do you recommend?
giallofly
Member #: 164
The Stig..
Newport Pagnell
Try these http://www.aet-turbos.co.uk/
will be interested to see how the 6 speed box holds up with lots of torque.
Who's rollers are you going on?
Edited by Jimster on 7th Sep, 2005.
Looks like a nice motor, similar (but not identical) to others on this forum.
No one else using a 6 speed box mind.
I assume you have an intercooler?
Jim, he already said minispeed.
oops sorry
mini300bhp
Member #: 653
Cambs
Click on the link and look at my avatr. Im thinking of getting a bigger one because I split the core on this one . I've welded it up but its made a mess a bit.
mini300bhp
Member #: 653
Cambs
cheers for the turbo link giallofly. Which turbo would you recomend for max 'bannanas'.
your intercooler looks rad! *happy*
That is a nice looking intercooler.
It's a cool looking car in fact, not sure how you get in with all those tubes in it.
Good luck with 200bananas, I'll predict 180 though.
Wil
mini300bhp
Member #: 653
Cambs
Thanks guys. I still need to get the shell painted when I'm happy with it and finnish the inside.
You are best talking with AET yourself re the turbo....
