| Home > General Chat > drill bit specifications | |||||||
25th Jan, 2016 at 11:32:19am
well, after a frustrating evening of progress on the metro last night, I spent 3 hours to end up slightly behind where I started. How I managed it, I don't know, but I sheared both the screws that hold the choke mechanism onto the carb.
25th Jan, 2016 at 11:45:00am
Go to an engineering supplier being careful not to run out of diesel on the way and buy yourself a set of Dormer TiN coated (Titanium Nitride) drills. Use them only for precise work (e.g. not for boshing a 8.5mm hole through a panel to mount something) and they will last you years. Edited by Tom Fenton on 25th Jan, 2016.
25th Jan, 2016 at 12:24:26pm
+1 for set of proper dormer bits, they dont need to have fancy coatings or anything just dont abuse them.
25th Jan, 2016 at 12:30:21pm
cheers guys; i'll do a bit of fishing based on your suggestions |
25th Jan, 2016 at 12:51:38pm
I wish someone could teach me to re-sharpen a 1/8" drill !
25th Jan, 2016 at 01:03:08pm
Also I like a nice tungsten bit for pilot holes, although it should be a central drill really I spose.....
1391 Posts Member #: 1686 Post Whore Oxford |
25th Jan, 2016 at 06:00:18pm
You are probably destroying your drill bits by running them too fast and not feeding fast enough.
OMG Robert that's a big one |
25th Jan, 2016 at 06:01:50pm
Or even split point drills. I used to use them when pushed for time
25th Jan, 2016 at 07:00:33pm
Yes, jacobs chuck. As for speed, i'm not sure what i've got the drill set at - its not particularly fast though, i could probably count the revolutions if i tried but its something to take note of.
On 25th Jan, 2016 Sam said:
You are probably destroying your drill bits by running them too fast and not feeding fast enough. Are you using a spotting drill too? But for precision work a jacobs chuck is dreadful. For anything other then clearance I wouldn't be using jacobs chuck. A neat trick to use if you are really having problems with accuracy is to drill the hole say 0.2mm undersized then use a drill with the corners rounded off at the appropriate size. You'll get at least a h7 fit out of it. |
25th Jan, 2016 at 08:14:07pm
The smaller the bit, the faster the required speed. You might be surprised at the difference in recommended speed as the bits get bigger. There is probably a chart on the net somewhere detailing it. |
25th Jan, 2016 at 08:26:28pm
Always use a centre drill first and the drill bit won't wander. If it's wanders off with a pilot hole, then it's likely that the drill tip isn't sharpened in the centre. The main thing that blunts drills is heat, especially on smaller drills, so cutting fluid is your friend here.
Edited by matty on 25th Jan, 2016. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Jan, 2016 at 08:26:31pm
Double post! Edited by matty on 25th Jan, 2016. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Jan, 2016 at 09:23:13pm
I find cobalt are the best for what I do, nice and slow with cutting fluid from tool Station. I have started posting on Instagram also my name on there is turbomk1golf
25th Jan, 2016 at 09:58:38pm
I've got a bottle of this stuff, make no mistake its MEGA
25th Jan, 2016 at 10:45:14pm
Not sure where the cutting fluid i use comes from. I generally borrow it from nicks bench at the other end of the shed! |
26th Jan, 2016 at 01:39:15am
Whats the problem anyway. Are your holes the wrong diameter or in the wrong place? (Or wandering?)
26th Jan, 2016 at 08:21:23am
also as a side note,
26th Jan, 2016 at 11:55:02am
I was trying to drill a steel screw out of the alloy body and bit was wandering. I've managed to fanny it up so it will work but not my best work to be honest. Was using small bits to be fair but I've noticed on some of the larger elements of work, the bits can wander too. No apparent play in the spindle or chuck so I'm putting it down to the bits and perhaps poor start prep on how I go about it
On 26th Jan, 2016 slater said:
Whats the problem anyway. Are your holes the wrong diameter or in the wrong place? (Or wandering?) |
26th Jan, 2016 at 12:44:18pm
How about the DeWalt Extreme 2 sets? They have a self centering tip design.
26th Jan, 2016 at 02:58:02pm
Too late for you Rob, But I use a centre drill to mark the job when drilling steel out of alloy
26th Jan, 2016 at 03:17:39pm
If you're drilling a bolt out, you need to look to see where the thread ends and offset the centre drill the thread depth towards that side. As you look at the broken bolt/stud what looks to be the centre of bolt actually isn't,and you'll end up with a half moon shape left on one side and drill the thread out on the ally part on the other, when you get to the core size of the thread...if that makes sense? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Jan, 2016 at 05:07:03pm
get where you are coming from and I did try to mark the top of the screw but to be fair, my centre punch was really too blunt to get a fine point. Bear in mind the screws are perhaps equivalent to an M2 or 2.5 so the bits I was using were 2mm and 3mm so it was fine work
![]() 243 Posts Member #: 1261 Senior Member Droitwich |
26th Jan, 2016 at 07:48:34pm
try something like this maybe?
26th Jan, 2016 at 08:42:08pm
On 26th Jan, 2016 Rob Gavin said:
get where you are coming from and I did try to mark the top of the screw but to be fair, my centre punch was really too blunt to get a fine point. Bear in mind the screws are perhaps equivalent to an M2 or 2.5 so the bits I was using were 2mm and 3mm so it was fine work its all a learning curve and I simply want to get myself prepared for the future Ah if you've got something that small your always best to find another piece of metal at least with a thickness of 1.5 X the diameter of the drill your using and drill a hole in that and use that to guide the drill straight. Centre drill the bolt, replace centre drill with drill bit, then use the drill bit to align guide plate, clamp guide plate down to job then this will help keep the drill steady. You can remove the guide once the drill has started cutting and at a reasonable depth. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Jan, 2016 at 11:12:26pm
Never seen that before - neat trick. |
.jpg)
