| Home > Technical Chat > knock knock | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
17th Oct, 2005 at 09:42:23am
anyone seen this? Knocksence diy kit, even plugs into the MegaSquirt too :)
18th Oct, 2005 at 12:59:40pm
...............................//tumbleweed/..............
18th Oct, 2005 at 01:02:16pm
I think there have been threads on this before. The basic config of the a series (e.g. 3 main crank) means there is going to be a lot of background 'noise' making accurate knock detection difficult........
18th Oct, 2005 at 01:38:29pm
Mike, why not be the innovator and report back? On 17th Nov, 2014 Tom Fenton said:
18th Oct, 2005 at 02:30:15pm
ok, sod it, i'll be the one that gets laughed when u all turn round and say 'told you you couldnt do it'!!!
18th Oct, 2005 at 03:27:07pm
Hey, that's the way to do it!
18th Oct, 2005 at 05:44:36pm
err, what do i reply with?!?! i know f-all about knock sensing!
19th Oct, 2005 at 10:27:16pm
"good idea boss" |
20th Oct, 2005 at 07:06:07am
"Mike,
20th Oct, 2005 at 08:36:09am
Could you use one of the alternator mounting bosses cast into the block perhaps??
20th Oct, 2005 at 08:44:22am
is that central enough? would save the posability drilling into a gallery tho i suppose.
20th Oct, 2005 at 09:52:08am
Don't know. It has the main advantage of being already there though........
20th Oct, 2005 at 12:58:39pm
Isn't there knock sensor on the MPI mini? where is that mounted? Team www.sheepspeed.com Racing
20th Oct, 2005 at 01:06:22pm
I didn't think they used one? But I could be incorrect there?
20th Oct, 2005 at 01:17:05pm
I could be wrong too Team www.sheepspeed.com Racing
20th Oct, 2005 at 01:26:27pm
MPis dont have one
AlexF |
20th Oct, 2005 at 01:37:21pm
any prefs on front or back? Are there any 'safe' areas away from water galleries? I guess i only need 10mm deep.
20th Oct, 2005 at 01:43:59pm
I'd go with the front, or it will BBQ under the turbo!
AlexF |
20th Oct, 2005 at 01:46:26pm
k, any pointers on wheres safe?
20th Oct, 2005 at 01:50:56pm
just use the casting marks on the outside to miss any oil galleries...
AlexF |
20th Oct, 2005 at 03:23:48pm
would the distributor screw be a decent place? thats on the front half way down? |
46 Posts Member #: 733 Member Gatwick |
27th Oct, 2005 at 09:57:24am
I have not seen a Knock sensor DIY kit before, however I am running a knock sensor on my ECU system and this detects knock within a certain freqency band (learnt from running an A series into the ground) and retards from the base map until the knock stops, this works on a per cylinder basis, so it is possible. But it is part of an ECU system not a plug in/standalone.
27th Oct, 2005 at 10:12:37am
y i've got a megasquirt ecu, and this knocksence has been built to work with the megasquirt. i'm sure there probably another/better/different/cheaper way to do it but hey!
27th Oct, 2005 at 02:22:22pm
On 27/10/2005 09:57:24 nigel said:
I have not seen a Knock sensor DIY kit before, however I am running a knock sensor on my ECU system and this detects knock within a certain freqency band (learnt from running an A series into the ground) and retards from the base map until the knock stops, this works on a per cylinder basis, so it is possible. But it is part of an ECU system not a plug in/standalone. It has been running well for over a year and on various RR sessions has been seen to be detecting knock and generally doing it's job. Sounds like an expensive ECU??? On 17th Nov, 2014 Tom Fenton said:
3 Posts Member #: 736 Junior Member |
28th Oct, 2005 at 12:20:14pm
hi guys, i have a similar knock detection unit from www.turboxs.com on my subaru wrx and will be fitting one to my mini conversion, i personally think its brilant and works and looks great here's some info about the turboxs KnockLite from the website.
