| Home > General Chat > OT - A-series Diesel Engine | |||||||
1st Nov, 2005 at 04:48:58pm
Totally forgot i had these pictures up on the 'net... On 17th Nov, 2014 Tom Fenton said:
1st Nov, 2005 at 05:21:01pm
Isnt that the same as a BMC tractor?
1st Nov, 2005 at 05:26:41pm
Talking odd diesels, bloke at work was on about a three cylinder 2 stroke, with 2 pistons a bore travelling opposite directions
1st Nov, 2005 at 06:06:43pm
On 01/11/2005 17:21:01 iain said:
Isnt that the same as a BMC tractor? if so then i've seen plenty
Yes it is - but not the larger (B-series based) 1800 (leyland 154 for example)... This is the real A-series based unit... In all my years of being a (sad - i know) tractor enthusiat, i'd heard of, but never seen the smaller version... On 17th Nov, 2014 Tom Fenton said:
1st Nov, 2005 at 06:33:59pm
it's bearly an A series if it is lol. Best 1/4 mile 13.2 seconds @116 mph
1st Nov, 2005 at 07:46:38pm
I can remember an a'series diesel we had at college, it was all plumbed up on a stand but never got the chance to see it running. -MINI CLUBMAN 1380 TURBO- |
2nd Nov, 2005 at 07:29:19am
On 01/11/2005 19:46:38 T3Tone said:
I can remember an a'series diesel we had at college, it was all plumbed up on a stand but never got the chance to see it running. Because it probably didn't :) On 13th Jul, 2012 Ben H said:
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
2nd Nov, 2005 at 07:32:19pm
on what dangerous said, i read that all 2-stroke diesel engines have to be turbo/super charged (i guess to make the temps needed to ignite the fuel) so maybee instead of a turbo they used like a second piston to make a more compression?
2nd Nov, 2005 at 07:57:35pm
you read wrong |
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
2nd Nov, 2005 at 08:34:04pm
And lest we forget, diesel ignites due to high compression ratio. You can put flame to it, and all it will do is smoke, unless it's compressed.
![]() 71 Posts Member #: 529 Advanced Member Stoke-On-Trent |
2nd Nov, 2005 at 08:56:56pm
On 02/11/2005 20:34:04 Dr. jinG said:
I'd love to do a diesel conversion on a Mini! But fat chance getting a diesel motor/tranny/diff that will fit under the standard bonnet... Boohoohoo...
saw one a few years bak, using the daihatsu charade three cylinder TD engine. |
2nd Nov, 2005 at 09:29:38pm
HAsn't Gaydon got a diesel A?
AlexF |
2nd Nov, 2005 at 11:34:36pm
Don't believe so - but they do have the Turbocharged diesel Rover V8 - Project Iceberg.
3rd Nov, 2005 at 07:47:59am
A 2-stroke diesel does indeed have to be blown. This because they have no inlet valves. Have a look at www.howstuffwork.com and you'll understand. On 13th Jul, 2012 Ben H said:
3rd Nov, 2005 at 07:59:44am
they did use these engines as small marine generaters as well i have seen a few in my time whilst at see.
3rd Nov, 2005 at 04:23:00pm
I went to Watsons today (the vtec conversion place in wakefield) and he is on with a diesel mini project. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
3rd Nov, 2005 at 05:59:13pm
Vegard, i can 100% guarantee you that a 2 stroke diesel does not have to be blown.
4th Nov, 2005 at 08:04:43am
Ok, I stand corrected, but I do not at all understand how it works without. Does it have valves? On 13th Jul, 2012 Ben H said:
4th Nov, 2005 at 08:48:02am
I'll check but i think so |
4th Nov, 2005 at 09:00:26am
normally has a inlet port and a exhaust valve ( or was it the other way round).
4th Nov, 2005 at 12:52:56pm
http://www.steamengine.com.au/ic/engines/s...e/diesel-2.html
Edited by miniturbo666 on 4th Nov, 2005. |
4th Nov, 2005 at 02:23:25pm
Yep thats a blown 2 stroke diesel but the one i have isnt |
2nd Dec, 2006 at 09:07:09pm
Dave, is this an A seried or B seried one?
2nd Dec, 2006 at 09:28:28pm
Model engines, the ones that run on "nitro" fuel are compression ignition and NA. If I showed up with a turbo'd lump at an 1/8th national I'd quickly be sent home ...... LOL
2nd Dec, 2006 at 09:39:05pm
I thought that the whole point of a 2 stroke was that the movement of the piston down the bore on the power stroke compressed the inlet charge in the crankcase forcing it in through the inlet port. A type of forced induction if you will. At least that's how nitro 2 strokes work. On 7th Nov, 2008 Nic said:
