| Home > Technical Chat > Fuel Pump for Turbo Engine | |||||||
1300 Posts Member #: 829 Post Whore essex |
2nd Jan, 2006 at 09:24:35pm
can i use a renault 5 turbo fuel pump on my turbo project i have modified the fuel tank by welding in a 8mm pipe in the top of the tank for the return fuel and fitted new fuel lines in 8mm pipe and fitted the metro fuel reg under the bonnet i also made up a fuel pump loom like era but not yet fitted the resistor do you need it 1293 Turbo mini
2nd Jan, 2006 at 09:29:49pm
I would imagine you could, as long as it delivers enough pressure and flows enough. No idea what the metro one kicks out.
2nd Jan, 2006 at 10:11:47pm
the metro turbo pump well run at 80lt/hr 25psi in std use 1293 Turbo mini
2nd Jan, 2006 at 10:13:43pm
Well there you go, find out what the renault unit produces and robert is your mothers brother |
2nd Jan, 2006 at 10:14:53pm
I'm 100% sure the R5GTpump will be fine...
2nd Jan, 2006 at 10:31:59pm
thanks all for your time i will go to renaults tommow Edited by jimmy on 2nd Jan, 2006. 1293 Turbo mini
3rd Jan, 2006 at 06:13:29pm
i phoned renault today and the pump run 3bar so it makes it 43.5psi so this means i can run more boost 1293 Turbo mini
3rd Jan, 2006 at 06:47:24pm
ermm, not quite as simple as that I dont think........ |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
3rd Jan, 2006 at 07:11:13pm
mine is a 5 turbo pump and fpr...... simply because thats what i could get for nothing..... not that im tight fisted at all!!! And on the 7th day........... God created turbochargers! |
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
3rd Jan, 2006 at 07:40:23pm
A five pump should be fine as they manage to supply a larger capacity engine.
Whats going to break next!?
8th Jan, 2006 at 07:34:11pm
My Mate {Mike} has used a R5 pump for years now, and it's been fine.
8th Jan, 2006 at 07:41:39pm
On 03/01/2006 18:13:29 jimmy said:
i phoned renault today and the pump run 3bar so it makes it 43.5psi so this means i can run more boost well a 25psi pump will allow you to easy run 20psi boost! But sure, a 45psi pump will let you run 40psi boost if you has the need!! Wil Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Jan, 2006 at 07:51:27pm
40psi i make that 2.8bar on a 1293 i will need sc gearbox for boost like that and what cc chamber in the head 30cc or lower the piston cr 1293 Turbo mini
8th Jan, 2006 at 07:56:11pm
2.8bar?
8th Jan, 2006 at 08:05:00pm
what if you use water inj to what you looking at to must pressure for the head gasket or heat 1293 Turbo mini
8th Jan, 2006 at 08:52:02pm
I think you would have problems with getting a turbo to produce that amount of pressure and still be efficient. Also your charge would be extremely hot, making it unlikely you would be able to get charge temps down enough.
8th Jan, 2006 at 09:14:42pm
i'd be more worried about the big fucking holes in the engine where the rods and pistons used to be than the head gasket at 41psi.....
Edited by Nick on 8th Jan, 2006. On 20th Oct, 2015 Tom Fenton said:
8th Jan, 2006 at 09:25:29pm
what would you call safe boost on a 1293 with t3 1293 Turbo mini
8th Jan, 2006 at 09:52:10pm
depends...if its a 1293 with 21251 pistons then 4psi, if its a 1293 with JE pistons then a bit more. it depends on the entire build dude, need more info to determine a boost level. On 20th Oct, 2015 Tom Fenton said:
8th Jan, 2006 at 09:59:59pm
head std
1293 Turbo mini
8th Jan, 2006 at 10:07:44pm
Std head means even with large dished pistons you are going to be at approx 8.5:1 at a guess
8th Jan, 2006 at 10:17:25pm
thank`s for post
1293 Turbo mini
8th Jan, 2006 at 11:29:26pm
Have a search of old posts, it is definately on here somewhere.
8th Jan, 2006 at 11:40:50pm
ok im looking thank`s tom 1293 Turbo mini
8th Jan, 2006 at 11:44:17pm
Here you go
