| Home > Help Needed / General Tech Chat > Minisport 4 Pin Diff | |||||||
47 Posts Member #: 665 Member Birmingham |
25th Jan, 2006 at 06:39:27pm
This may sound like a stupid question but with this diff does it make any difference which engine its in i.e. an A series or A+? Or are there two different types? |
1300 Posts Member #: 829 Post Whore essex |
25th Jan, 2006 at 06:42:38pm
it will fit both 1293 Turbo mini
25th Jan, 2006 at 06:46:52pm
Thanks for the reply
25th Jan, 2006 at 07:09:33pm
forget the MINISPORT diff these are crap!
25th Jan, 2006 at 07:11:15pm
yes the diff will fit because i had 1275 A and the engine blow up and i fitted a metro 1275 A+ engine and used the diff all the std pots will fit in the diff 1293 Turbo mini
25th Jan, 2006 at 07:20:20pm
Agreed with benross, go for the minispares x pin diff. -MINI CLUBMAN 1380 TURBO- |
25th Jan, 2006 at 07:21:12pm
yes yes yes yes yes x pin diff from minispares Edited by jimmy on 25th Jan, 2006. 1293 Turbo mini
25th Jan, 2006 at 07:29:44pm
Benross so I should be looking for a Minispares one looking to try and get around 150 bananas from my metro turbo lump.
25th Jan, 2006 at 07:36:49pm
the verto clutch is ok for 120 bhp 1293 Turbo mini
25th Jan, 2006 at 07:59:50pm
On 25/01/2006 19:36:49 jimmy said:
the verto clutch is ok for 120 bhp maybe be on an n/a engine.... it lasted a month at 120bhp on my turbo lump, surely its the torque that kills em rather than hp? On 20th Oct, 2015 Tom Fenton said:
25th Jan, 2006 at 08:05:58pm
go for a non verto set up, race/rally plate and a grey diaphram
25th Jan, 2006 at 08:07:37pm
Bud what clutch are you using? What figures are u putting out im looking to push towards 150 bhp and as much torque as i can get |
25th Jan, 2006 at 08:18:33pm
i'm now using the same as what Nic has just suggested up there ^^^ :) no idea on figures at the minute, going to the RR in brum on saturday though so i'll know then... On 20th Oct, 2015 Tom Fenton said:
25th Jan, 2006 at 08:23:53pm
Iv' e got one similar to the series 2 escort both size and dimensions.
25th Jan, 2006 at 08:31:43pm
squinty what are you running straight cut drop gears and straight cut gearbox with power 150hp and up ? 1293 Turbo mini
25th Jan, 2006 at 08:47:51pm
looking for straight cut drops uprated clutch and diff 150bhp max |
25th Jan, 2006 at 08:54:55pm
what set of straight cut gears did you use jack/knight or minispares 1293 Turbo mini
25th Jan, 2006 at 09:05:25pm
Still yet to buy the drops diff and clutch just after a bit of info first as this is my first build |
25th Jan, 2006 at 09:11:38pm
minispares do a sc gear set for the gearbox for about £400 1293 Turbo mini
25th Jan, 2006 at 10:27:38pm
yes the clubman gearset is fabola that’s what i run as it incorporates some of your old helicals as well which cuts down on the price.
26th Jan, 2006 at 07:04:58am
Just fitted one this weekend:
29th Jan, 2006 at 08:32:41pm
Do you guys think the standard gears are up to taking the power i want If i just change to a cross pin diff and straight cut drop gears?
Edited by squinty on 29th Jan, 2006. |
29th Jan, 2006 at 11:12:16pm
My personal opinion is that 150bhp on the standard gears is going to be very marginal and potentially not very reliable. Consider the damage a grenaded gearbox can do to your expensive engine, this is the main reason I went for full straight cut gears.
19th Jun, 2006 at 04:38:22pm
i know this is an old post but, is the minispeed cross pin diff any good?
My build thread..
19th Jun, 2006 at 07:16:04pm
pass on that one josh ???
