| Home > Help Needed / General Tech Chat > Actuator Plumbing Puzzle! | |||||||
30 Posts Member #: 594 Member Hitchin |
1st Feb, 2006 at 11:08:27pm
Theres a T Peice in the Turbo compressor housing one goes to the Actuator and the other goes where?
1st Feb, 2006 at 11:21:06pm
the spare one you've got went to the boost solenoid i think on the metro. It's blocked off on mine now anyway. On 20th Oct, 2015 Tom Fenton said:
1st Feb, 2006 at 11:30:13pm
so the connection on the top of the regulator should just be 1 pipe going to the plenum?
1300 Posts Member #: 829 Post Whore essex |
1st Feb, 2006 at 11:35:41pm
yes 1293 Turbo mini
1st Feb, 2006 at 11:36:36pm
seconded
2nd Feb, 2006 at 08:49:18am
So how does the Actuator receieve its pressure signal? |
2nd Feb, 2006 at 08:50:35am
From the T piece that it is connected to.
2nd Feb, 2006 at 09:53:30am
cheers for all this much needed help!
2nd Feb, 2006 at 11:43:00am
idealy put the bleed off some were from turbo housing and the actuator . always looking for them bigger bunches of bannanas |
2nd Feb, 2006 at 11:44:59am
yup, my bleed valve is inline with the pipe from the comp housing to the actuator. On 20th Oct, 2015 Tom Fenton said:
2nd Feb, 2006 at 12:05:22pm
So if i block of that spare pipe, and put the bleed valve inline, on the pipe that goes from the turbo to the actuator, that should be ok? |
2nd Feb, 2006 at 12:51:46pm
2nd Feb, 2006 at 01:28:45pm
there are many diffrent ways to plumb the actuator up but they all lead to the same goal. Edited by BENROSS on 2nd Feb, 2006.
2nd Feb, 2006 at 02:08:31pm
ok i've tried blocking of the loose pipe of the actuator and having a single pipe going from the plenum to the regulator.
2nd Feb, 2006 at 02:14:14pm
Post up some clear pictures showing us how you have it arranged.
Edited by Tom Fenton on 2nd Feb, 2006.
2nd Feb, 2006 at 02:18:57pm
On 02/02/2006 14:14:14 Tom Fenton said:
If you tee it into the servo pipe you will not get a reading, due to the check valve in the take off from the inlet manifold, which stops the turbo from pressurising the servo. on the top of the inlet manifold you have the servo takeoff, on top of this is a small nipple this is wherei have my dump valve connected? would this be the reason for the dump valve sounding sluggish? or is this the correct place to put the dump valve connection? |
2nd Feb, 2006 at 02:34:12pm
you want the dump valve trigger onto the inlet manifold, rather than through the servo take-off as it has a one way valve in it. I've got a couple of extra nipples put on my inlet for the boost gauge and the dump valve. Edited by Nick on 2nd Feb, 2006. On 20th Oct, 2015 Tom Fenton said:
2nd Feb, 2006 at 02:43:28pm
If you tee it into the servo pipe you will not get a reading, due to the check valve in the take off from the inlet manifold, which stops the turbo from pressurising the servo. on the top of the inlet manifold you have the servo takeoff, on top of this is a small nipple this is wherei have my dump valve connected? would this be the reason for the dump valve sounding sluggish? or is this the correct place to put the dump valve connection? To clarify- Above the servo take off (which doesn't have a valve on the inlet, it is further up the pipe) there is a connection which was used on the metro as part of the breather system. This has a one way check valve in it which is used to stop the turbo pressurising the breathers. This is why connecting your boost gauge here does not work. Connect it to the pipe off the side of the plenum. Also connecting your dump valve here is not ideal either. Follow bud's advice and add a couple of nipples to your inlet for the best solution.
2nd Feb, 2006 at 02:58:49pm
Would that be the reason why the dump valve dosn't sound as loud as it should?
2nd Feb, 2006 at 04:18:26pm
Who else has theis connected as ben has drawn?
2nd Feb, 2006 at 04:22:19pm
The only reason I can see for having the check valve would be to prevent any chance of the engine drawing un-filtered air through the bleed valve if running at high vacuum off-boost?
2nd Feb, 2006 at 04:40:18pm
wil i have updated the drawing to the compressor housing and not the manifold
2nd Feb, 2006 at 04:41:35pm
So is there anywhere to effectivly put the dump valve trigger pipe untill i get 2 nipples put into the manifold? |
2nd Feb, 2006 at 04:43:47pm
T-piece from the manifold. one to the boost gauge and one to the dump valve. This is a permanent solution on my car.
2nd Feb, 2006 at 05:08:30pm
But i haven't got any nipples/connections coming out of the manifold except from the servo takeoff part?? |
