| Home > General Chat > What clutch do you use? | |||||||
28th Mar, 2004 at 11:03:48am
I'm still on the std verto one ATM... but thinking of changing, I doubt slicks and a std clutch are going to work well LOL. AlexF |
28th Mar, 2004 at 11:10:42am
single grey,
28th Mar, 2004 at 11:23:00am
and no problem with thrusts on a grey?
AlexF |
28th Mar, 2004 at 11:24:15am
![]() 323 Posts Member #: 41 Senior Member |
28th Mar, 2004 at 01:12:55pm
i run an orange dia with the same plate as dave i think, AP road/rally item. fine for std boost, might have to change to grey if the boost is turned up alot. A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
263 Posts Member #: 115 Senior Member Austria, near Vienna |
28th Mar, 2004 at 08:07:06pm
Dave, what is the original height of the backplate lugs? Do you increase the pressure of grey diapr.?? Bimmer Twinky headed and turboed A-Series:
28th Mar, 2004 at 08:23:45pm
when I run a grey with a AP organic road/rally plate with the lugs at std hight, I got clutch slip on full boost Team www.sheepspeed.com Racing
28th Mar, 2004 at 09:22:51pm
Shortening the lugs solved the problem? I had the same problem in a quarter mile run last year; but only when I was using 1,2bar (18psi), and only in 4th gear at 4000rpm for a very short time. (maybe for 2 seconds). Have you ever tried a douple grey dia?? Bimmer Twinky headed and turboed A-Series:
![]() 2641 Posts Member #: 19 Post Whore newcastle |
28th Mar, 2004 at 10:23:20pm
what sort of times are you running??? Everyone knows that instructions only have to be read if the thing doesn't work....
28th Mar, 2004 at 10:31:45pm
quicker than you!! On 21st Jan, 2011 fastcarl said:
28th Mar, 2004 at 10:47:56pm
no bacon butties for you then !! Everyone knows that instructions only have to be read if the thing doesn't work....
29th Mar, 2004 at 12:26:56am
Harry,
29th Mar, 2004 at 08:13:44am
* Off to the Lathe *
29th Mar, 2004 at 11:28:21pm
Dave, thanks for this interesting information! Good research!
30th Mar, 2004 at 12:46:49am
Whats the pedal feel like with the grey? compared to standard verto as i only have experience of verto :) turbo 16v k-series 11.9@118.9 :)
1st Apr, 2004 at 12:41:27am
bumpio :) i do alot of town driving so realy would like to know the answer to this. turbo 16v k-series 11.9@118.9 :)
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
1st Apr, 2004 at 03:21:41am
not sure if you have seen my post just below this one also about clutch but you will see i have a comp AP plate with orange cover and it does not bite very hard and i can slip it and the pedal is hard but very acceptable.
179hp on 12psi 1293cc of pure A series
1st Apr, 2004 at 12:25:53pm
I find a grey is fine, although my mrs did complain it was a bit heavy, but she still wanted to drive it all the time Team www.sheepspeed.com Racing
1st Apr, 2004 at 06:35:46pm
Cheers :) was jsut worried as i spend alot of time wirth my foot on the clutch crawling about the city centre in rush hour :( turbo 16v k-series 11.9@118.9 :)
1st Apr, 2004 at 07:50:55pm
sure a grey diph isn't the best in town jungle , but you can use neutral instead of staying with your foot on the clutch pedal |
1st Apr, 2004 at 08:20:16pm
welo the trouble with glasgow centre is thers alot of lights on steep hills, so slipping of the clutch is a necesity, besides every time i change to neutral the lights go to green, so its not an option turbo 16v k-series 11.9@118.9 :)
1st Apr, 2004 at 11:26:46pm
I mounted the Metro clutch master cylinder with a -4 SSbraided pipe frome the master to the slave with a grey dia. - and the pedal effort is much less then with the original Mini setup on my other car with the orange diaphragma! Try it! you will be surprised!
2nd Apr, 2004 at 01:10:55am
metro master cyl a smaller bore? wil the pipe fittings from the mini setup work? turbo 16v k-series 11.9@118.9 :)
2nd Apr, 2004 at 06:07:21am
I fiitted a selfmade "bigger bore" -4 SS braided pipe from the master directlly to the slave cylinder. I opened up the outlet/inlet bore of the master and Minislavecylinder to 5mm. Maybe there is a reduction in friction of the moving transfer fluid?!; I never measured the bore of the Metro master! Is it smaller? - maybe the reason?! (Bought the parts from Think Automotive) Bimmer Twinky headed and turboed A-Series:
2nd Apr, 2004 at 04:33:00pm
well the bore of the pipe wont affect the static pressure (when ur sittin with ur foot onthe clutch) mety m-cylinder must b smaller i guess :S turbo 16v k-series 11.9@118.9 :)
