Home > Show Us Yours! > engine build with help from turbominis lot of pics
wintersurferuk
Member #: 2208
the oil drain is going into the dizzy hole, hoping this will be enough. time will tell.
On 30th Jun, 2010 rubicon said:
where did you end up doing the oil return?
i would have thought so,
how does is the clutch in its new place?
Thats looking great!
how's yours coming on neil?
cant belive paul's nearly done!!
is your excuse that you've been helping him?
lol
Yes, that and being skint.
george91
Member #: 8932
looking good, you have so much space in clubby fronts, and i didn't realise those megajolts were so small, liking it a lot so far and will be great seeing it finished. :)
Edited by george91 on 30th Jun, 2010.
wintersurferuk
Member #: 2208
im not sure about the clutch yet, should be bleeding it in the next few days :/
just waiting for the mj to get back, spark plus and 90 bend, then starting it! would like to get it going by the weekend, but want hold my breath.
tadge44
Member #: 2500
Buckinghamshire
Just read this entire thread and the last pictures look really great - and not a blue silicone hose in sight !!
Turbo Shed
Member #: 30
Epsom, Surrey
i was just going to say i'm glad you havent used any chav blue hose but tadge44 beat me to it, nice build
wintersurferuk
Member #: 2208
Thanks, the paln was to try and keep it looking OM, but im like a magpie and kept buying shiny things.
if you look hard enough you can see chave blue tube comming of the aturator, chave tower bolts and a blue boost wheel on the dash, and last but not least, a huge backbox!
next im fitting burbury seats with nike ticks on them!! im getting there, its the essex way!! *wink*
madcatminis
Member #: 5327
Dudley, West mids
Dude it's looking like an awesome build!!!!!!!!! *Clapping*
that tail pipe actually looks ok, I thought it was going to be much more chavvy
wintersurferuk
Member #: 2208
it did look alot bigger untill it got under there!
may lower the car a little more...
It looks so much better on. You've done well. Will it allow you to drop the car some more then?
wintersurferuk
Member #: 2208
well,
god ive needed this site this week!!!!
got round to filling the car with water only to see it flow out the head through the 11stud hole, so that answer to "do i have to have 11studs"
so everything is done appart form the alt which i couldnt do as the site was down *indifferent*
got the car started last night, first turn of the key, so sweet to hear it for the first time, ran sweet for a few minis....
then started smoking, heres where i have a problem, its not the block.
the turbo was spueing oil into the down pipe, when ive taken the oil drain off the dizzy plug, and let it drain onto the floor, the smoke stops,
so its one of three things!
the oil drain isnt working.
the turbo propper fooked!
or its the pear of them...
the turbo did have loads of play, and when the cars running it has 80-100 psi of oil going through it. cant beleave just how much oil go's through the turbo, over a liter in less than a mini!
so ive ordered a rebuild kit and going to go from there! wish me luck!
Is the oil drain pipe low enough, in that it's always lower than the Turbo ? as it drains under gravity.
well, the drain is about an inch lower than the turbo, but is about 8" away from the turbo so it is at quite a shallow angle,
the fact so much oil is coming out of the turbo suggests to me the turbo is the problem,
Also i didnt realise you oil press was that high Paul, that wont help, turbo's are only meant to see about 60psi max
We'll see what happens after we rebuild the turbo. It's got a shitload of play in-out and side to side.
MJ is fucking brilliant. It started on the first flick of the key!
my 123's like that on the black one,
starts easy as no matter how long its stood, or even if the batterys proper flat
wintersurferuk
Member #: 2208
the turbo itself is a good few inches above the dizzy drain hole, then theres the pipe comming out of the turbo which falls about an nich, then a rubber hose going to the dizzy, im out there tomo taking it off so will try to get some photos of it. at no point does the hose bend up, it just quite a mellow fall.
wintersurferuk
Member #: 2208
well the turbos off, got some pic of the oil drain, i think im going to tweek it to make it shorter and try to get a bit more of a slope on it. rebuild kit came today so will be rebuilding that as well, good news is there wasnt any oil in the manifold before the turbo,
wintersurferuk
Member #: 2208
well with the help of gary we rebuilt the turbo. there was plenty of play before and was worried the oil could be comming through the oil seel.
with the turbo rebuilt theres alot less play in the turbine.
fitted everything back to the car appart form the oil feed banjoe, which i managed to cross thread into the turbo and fuck both threads!
so im going to see if i can rescue the thread.
DOH!
it dosent look too trashed, i reckon it should go in as long as your careful,
thread it in getly a bit at a time checking it for straightness as you go.
If you get a new banjo bolt, I've got a fitting we can use on the turbo.
even better,
whats the thread, i have a few banjo bolts knocking about
