Home > A-Series EFI / Injection > CNC Billet Injector Bosses and Manifold
BTW, how come you're down to two injectors.....
I thought the original plan was three to get symettry with staged injection ???
(first picture at beginning of thread),
I've gone down to 2 injectors because that's all I need and it is simpler to make - much simpler. You can now get 1000cc/min injectors that will fit which will do well over 200hp. I'll be using 600cc/min for up to 150hp on the 998.
I used 3 in the original because at that time the biggest pencil injectors were 800cc/min and I was looking for some headroom.
As for symetry, I don't think that offsetting the injector by 10mm from the centreline of the port will have much affect at idle and cruise, given the distance from the injector to the valve. It will be symetrical under boost with all four firing.
jamie@thefatgarage
Member #: 9345
Sheffield
If you are going to be gluing stuff together you might consider plastic rather than aluminium. I've used acetal machined for inlets before. Chemical and temp resistant, dimensionally stable and a piece of piss to machine. Comes in lots of shapes and sizes. Glues together with superglue and a primer. Cheap too from directplasticsonline.co.uk. I made little manifolds for my quad with it..
KLAS
Member #: 2380
Hamburg, Germany
google DIY bead tool and you will find some very handy ideas to make your own.
like out of a vise grip, a muffler clamp and a woodruf key. or if you want something with rollers you could fit the rollers, bought or home made, to your vise.
nothing for high volume production, but if you only need some made
I thought about using plastic, particularly the use of 3D printing. BUT the inlet has to share a mounting stud with a near red hot turbo manifold. I'm not aware of a plastic that will cope with the conditions.
jamie@thefatgarage
Member #: 9345
Sheffield
Perhaps a metal flange and plastic glued after it for the compicated bit.
Thanks, this is just the job:
http://honda-tech.com/showthread.php?t=2922371
KLAS
Member #: 2380
Hamburg, Germany
or something like this
http://forums.turbobricks.com/showthread.php?t=58790
think you would need something to turn the pipe, like a strap wrench
On 21st Nov, 2012 Paul S said:
I can't weld a bead without destroying the pipe, I've tried :(
Really? What wall thickness is it? I've welded beads on 1.6mm ally lots of times now. What size tungsten are you using?
It was 1.6mm wall and a 2.4mm tungsten I recall. It was before I really got the hang of welding ally though. I could try again.
Edited by Paul S on 21st Nov, 2012.
I like that one.
Exactly....
Plastic/fibreglass/carbon fibre is all a really good idea......
But only on a crossflow head.
Mainstream manufacturers use it all the time - on crossflow heads - but it's not for the a-series.
....until someone proves me wrong...
Not to be a smug git but it really is very do-able, have another go. I use a 3.2mm tungsten on thin ally as it doesn't concentrate the heat so much in one area.
oli79
Member #: 8480
I used these rods to perform the alterations to my std metro plenum, solid and spot on looking joints but they were not all air tight when pressure tested, it bubbled out from under the edges of the 'weld', they were minor so the tiny loss of air pressure under boost never bothered me, car had may more larger shortcomings! Anyhow loving the engineering involved here.
Seriously thinking about using Easyweld to fix the runners and end plates to the plenum. Could really do with carrying out a pressure test on a pipe joint, just to satisfy any concerns over the strength of the bond.
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
i have used them on a few bits and bobs, if you have a perfect join and use this 'solder' stuff to stick it together its not bad but for bridging holes its crap
A poor workman blames his tools *hehe!*
*wink*
http://www.youtube.com/watch?v=jijW310xvp4
Edited by Sprocket on 22nd Nov, 2012.
the hole in the base of a can is easy try sticking 2 parts together where the join is round a corner and you will see what i mean, the stuff when molten runs like water and so easily settles in the bottom of the can base
that is airtight and works a treat *wink*
Edited by Brett on 22nd Nov, 2012.
what about the round pipe with its convex surface that would surely see the solder run off?
as with any soldering, applying the heat to the solder will always end in a mess. the trick is to heat the base metal and melt the filler rod onto it. Heat the part, not the rod *wink*
Like water, the hotter the solder, the thinner it becomes so controlling the temperature of the materials is key, but. That's the tricky bit wich takes some practice.
meh not arguing, i dont like it and think its crap for fabricating, never said i couldnt use it
I got the impression that it was a bit like old plumbers solder, if you controlled the heat you could keep it in a buttery state.
I'm still waiting for my crate of bananas :(
That's the bit that still eludes me......
I take your Saul Bellow and I raise my Stephen Hawking if you actually tell me what the bananas mean....
bent pipe sections to make the inlet pulsiness ?
No, just bananas:)
oli79
Member #: 8480
Well I agree brett, I have done more than my fair share of soft soldering, brazing, silver soldering and gas welding which I have always had a prefference for! The older plumbing solders reel or stick were at least 60 per cent lead which gave that window of butteriness at the right temp, body solder for lead loading even more so, this stuff they towt as a brazed joint in alloy and behaves nowt like soldert the key seems to be keeping the heat low just around the melting point of the rod and in the workpiece but rubbing the end of the rod into the surface to get it to adhere, they claim its needed to break the oxide layer formed, I found the same it behaves nothing like solder and if you try to treat it as such it will bead off out of the pool. I have been through 4 of the large tubes on various things and I don't rate it for fabrication, but its great for filling in type repairs such as corrosion dips and lumps out of alloy casings
[quote=Brett,22nd Nov, 2012]meh not arguing, i dont like it and think its crap for fabricating, never said i couldnt use it[/quote
My special US bananas are stuck in customs :(
So these will have to do :)
