Home > A-Series EFI / Injection > Who's actually got this running on a 5 port???
what kind of EGT temps are you guys seeing? I've not got sensors mounted but using an infrared thermometer my centre exhaust port is 512 deg c at idle
I logged around 700 Deg C on the centre branch on a low compression, low revving 998.
On my simulation of a stonking NA 1293, I've seen peaks of around 1300 Deg C as the exhaust valve opens.
The outer cylinders tend to run around 120 Deg C lower as the thermocouple only picks up a cycle average.
KLAS
Member #: 2380
Hamburg, Germany
thats why professional grade equipment measure the pressure now, too.
like http://www.ecm-co.com/product.asp?5220
nothing for the average people, for sure
On 12th Sep, 2012 Rod S said:
So if the datasheet is correct (ish), of course you can calculate the actual AFRs but only if you measure the actual pressures at the LSU.
IMO Jim for the set up for the race car your taking about, I don't think you'll gain any thing over a well set up carb.
Fueling issues aside, the biggest impact on power will be any change of inlet runner length and diameter.
If you change from a weber to a TB on an SU manifold, your inlet pulses will no longer suit the cam and head meaning a loss of VE.
IMO you should stick with the runner length from the head flange to the weber inlet trumpet.
thanks for all the input guys, if I could get the carb to fuel perfectly all the way through the rev range then I would keep it, but currently it's a compromise
Remember what Dave Wlker was talking about with a Weber and lower RPM on a wild cam *wink* and how EFI totally transformed it. Nothing to stop you using a Jenvey on the same Weber manifold with a pair of smaller injectors sized for the duty, fired in batch mode.
Also, remind me. I know there has been testing with a carb that shows cylinder AFR imbalance, and testing with the siamease code to show that it fundamentally works, but has there been testing with the SPi manifold or a custom double barrel to show that is any worse than a carb? Its been so long since all this started and I don't remember.
PaulH
Member #: 2340
Dublin Ireland
http://www.youtube.com/watch?v=DzU9QBAr1kc...player_embedded
The Dyno really does not lye same power same torque different manifold and pulls from lower down isnt this what you want Jim ?
On 17th Feb, 2009 Rob H said:
pretty much thats what I need.
t@z
Member #: 452
Chester, UK
why do they open the throttle so slow in that video? btw i have no sound just looks weird...
www.twitter.com/lilpinkiy
jbelanger
Member #: 831
Montreal, Canada
Power and torque might be good but that video also shows that fuel distribution is not good when you see even EGTs on all three ports (even though they claim it's a good thing).
How bad it actually is and what the consequences will be, I don't know. But there is definitely room for improvement.
Jean
http://www.jbperf.com/
Ever thought about using twin hif44's instead of the webber? Suposidly when tuned properly it gives alot better driveablity but keeps about the same for power, you could also still use good sized trumpets and mod the butterfly and carb body for better flow
Jean
I don't know about the consequences but I've logged lots of EGT and AFR data. The only time that the EGTs were the same was when the AFRs were 4 points apart. i.e. 15:1 on the outers and 11:1 on the inners. Turd polishing IMO.
I will not be logging egt's on this engine, only AFR's.
I understand what your saying about twin SU's but I'm trying to move forward, and twin carbs will be even harder to setup than a simple 45
Colin, I wish someone would.
Maybe someone has, but I've seen nothing on this forum.
And it's so easy on a N/A setup.
I looked that video up again yesterday (mainly to see what their peak EGTs were as Jimster asked) but it only shows the part throttle readings.
If you go back to the rather "fraught" thread originally on the SC setup, JK did say that his initial statement of EGRs being close was at part throttle and they were about 120 apart under load (which matches Paul/myself).
Unfortunately, like the AFRs, there isn't any real data at load (apart from torque/power).
Jim, I genuinely look forward to the results.
It won't put the turbo arguement to bed but will go a long way towards showing whether a wet manifold injection (with discrete pulses) can match a carb (continuous flow).
Any chance you will fit the two widebands before you take the weber off and give us some direct comparison ???
Rod.
Jim I can't see why you can't get suitable mixtures, you just need to get it to a good rolling road guy, get to T&M in colchester *wink*
Haha - 3 way tug of war.
Place your bets lads :)
I want to put the carb to bed, so want to try EFI, if I gain nothing I'll put it back on, but at least I know I've tried it. I will try dual wide bands before I remove the carb.
What I can’t understand is why I can’t got for a jenvey style twin TB to bolt on to the existing inlet manifold (rather than use a single TB like the video above). My thought is as long as the injectors are as close to the butterfly as possible then it should still work as good as a carb?? What are your thoughts on this???
The Jenvey twin TB on the existing manifold would be a great solution but you would run into problems with batch injection.
Each throttle would flow for approx. 360 degrees of a cycle filling first the inner cylinder and then the outer. Then there would be no flow for approx. 360 degrees whilst the other throttle fills the other 2 cylinders. If you inject during the dead period, then most of that fuel will go into the inner cylinder and very little in the outer.
You would need to inject about 60% of the port fuel requirement whilst the outer cylinder inlet valve is open.
The Holy Grail of 5 port injection is to get enough fuel into the outer cylinders.
On 14th Sep, 2012 Jimster said:
..... I will try dual wide bands before I remove the carb.
Good
I
A bit tricky to explain but here goes.....
To best replicate a carb (continuous mixing of air/fuel) an injection system needs to fire a minimum of 4 pulses per engine cycle with a high enough duty cycle (amount of time injector(s) are open compared to closed) to best mix the fuel/air.
But more importantly it needs to be done where the airflow is reasonably constant (for the given engine load).
The SC kit in the video probably uses two injectors (right next to each other) just for capacity though if JK reads this I'm sure he can clarify.
A weber setup, or twin throttle bodies feeding the two inlet ports independantly, will not have a continuous flow of air down each one, they will only flow air for half the engine cycle.
EDIT - depending whether the manifold has a balance pipe or not, but even if it does, the air flow will still pulse as the balance pipe won't flow the same as the main runner - END edit
So, for a start, you would need an ECU that runs sequential to match the alternating airflows and would need an injection regime that tried to add fuel to moving air.
Otherwise you could be injecting into stagnant air which not only would be minimal mixing, but could pool fuel in the runner, or adhere to the walls, just to be sucked into the first valve that opens (inner) which is basically the fundamental siamese port issue.
7/8 ports don't care if you pool the fuel in the runner or stick it to the walls (apart from things like acceleration enrichment but that's stil an equal problem on all cylinders), ultimately it will all go in the correct cylinder when the inlet valve(s) for that cylinder open.
So in summary, if you tried two throttle bodies, you really have a form of port injection (but with injection a long way from the ports) and all the problems that go with it.
The only realistic way you can run a "wet manifold" system and try to make an "electronic carb" is to replicate a single carb on a combined manifold.
Hope that makes sense.
Edited by Rod S on 14th Sep, 2012.
I was initially concerned about the direction of this thread, but its turned round nicely. Im actually understanding more of the problem and the reasons the different options are less than ideal. Keep it up *smiley*
NB
Member #: 10097
knowledge dropped. interesting read so far this, i'll be persuing something similar in the future so i'm looking forward to seeing what you come up with, Jim.
thanks guys, some good info. I think I'll go with the single TB, I'll do back to back tests on the dyno too. I'll keep you posted on how I get on.
Is there a calcuation to work out optimum TB size to keep port velocity up?
What about a modified head abit like carls twini with injectors pointing at each port, keep the standard port with i jectors coming from the top if that makes sence? Have them crossed so they fire to the opposit side for space? Surely then you wouldnt need siamease inj and use standard style setup?
Us the thin injectors and it could work, its different and new and could be the 5port efi solution, i would personally do this but dont have the machinary or tech knowlege.
Jim has fully sequential available to him, and the Emerald system that he already owns has an injector advance table. He doesn't have to pass the MOT, and the engine needs to make the beans between 6000 and 9000 rpm, and have better throttle response and pickup than the carb. Basically - his target is outright power in a somewhat limited powerband (albeit one with a tiny injection window)
I just think that he will be overall better off with straight runners (and ITB's) on each intake, which will better allow him to tinker with induction lengths.
Two of the modern Deka fast-responding injectors right by the head, and upping the baseline fuel pressure to 4bar, maybe more will all help.
