Home > Show Us Yours! > 1293 Turbo neon - Rebuild Pt2
Mike-998
Member #: 9774
Buckinghamshire
Did you check the end float? If there's excessive endfloat and you have to change the triangle or shim it to get it right it will change the sprocket alignment.
Nick warwick
Member #: 8926
Sheffield
I am picking up a new triangle plate this afternoon.
End load is checked by putting it all together and tightening all down isn't it? how do i measure how much movement i have?
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
same as your crank end float/thrust i believe
You have to install the triangle plate (6 possible way most of which look nearly right but only one is actually right) and then do up the big nut on the sprocket.
The ideal way to measure end float is with a DTI on the sprocket and gently lever it up/down with a blunt instument.
If you don't have access to a DTI, depending on the design of the aftermarket sprocket, you should be able to get feeler gauges inbetween the back of the sprocket and the triangle plate (with it levered up for the float in that direction).
Nick warwick
Member #: 8926
Sheffield
Nice one cheers for the info
I believe my DTi etc will be heading Nick's direction in the near future.
Nick warwick
Member #: 8926
Sheffield
How much end float should I have roughly?
couple of thou.
3-7 thou I believe.
If it's a new thrust plate I would expect 3 thou or less. A bit more on a used one.
Ideally you want similar to the crank so the chain stays straight.
With the standard setup it isn't adjustable, it's based on the thickness of the boss on the back of the sprocket because the triangle plate is clamped between that boss and the face of the end of the cam.
Aftermarket stuff may need adjusting with machining the boss or adding shims but hopefully not if the supplier did their job right.
Nick warwick
Member #: 8926
Sheffield
Would anybody like to purchase my uprated idle gear washers? extra strength.......
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
what the..
Nick warwick
Member #: 8926
Sheffield
The correct washers according to kappa. Gooooooooood one
lee.pb
Member #: 9199
Lancashire
Hi Nick, may i ask "whats with the oil drain plug".
It seems it was a good idea to strip the engine before installation.
Nick warwick
Member #: 8926
Sheffield
No idea haha, replacing it for a magnetic plug anyway.
Yeah it's been a long nightmare so far.
This cunt needs a turd in a box posting to him.
I would suggest you take that nut/bolt out ASAP and see what's behind it.
The only reason I can think of for a bodge like that is that the threads have been stripped.
If so you need to see if there is enough left to helicoil, otherwise the repair gets more complicated.
clubbie nl
Member #: 7701
Amsterdam Holland
Not a nice solution, but fairly better than sparkplugs i've seen there in the past.
It's a little car .... eating big money
Nick warwick
Member #: 8926
Sheffield
*Rofl!*
Nick warwick
Member #: 8926
Sheffield
From what i remember when i took the sump plug out it threaded back in fine and didn't leak when i put oil in when i first got the engine back hoping it would free up.
That is outrageous! Lol
Mike-998
Member #: 9774
Buckinghamshire
Are you planning on stripping the 'box down as well?
Nick warwick
Member #: 8926
Sheffield
That wasn't in my plan/budget.
I do have a good gearbox on my other engine which i am very tempted just to use and just swap the x-pin diffs over. The only problem i will have is to get a reducer bearing fitted for the drop gears as they are pre a+
Will a SPI fuel tank be alright guys? how easy would it be to fit a MPI pump? (if i could get a cheap one)
dev 11
Member #: 9393
stoke on trent
I have his address if anyones feeling a big shit in a parcel.
Spi tank delivers up to 1bar fuel pressure so up to 10psi boost should be ok.
