| Home > General Chat > Thoughts on proposed Electric water pump installation. | |||||||
25th Jul, 2006 at 12:00:54am
I may be totally off the track with this but why not take water from the bottom rad hose (cold water) and push it with the booster pump into the core plug. That should cool the engine and the head since this should get out normally either through the heater takeoff or the thermostat housing.
25th Jul, 2006 at 07:18:12am
Sorry dave, can't make picies, there is a bimi blower at this place now :) |
25th Jul, 2006 at 01:38:45pm
jean, do you mean a core plug on the other end of the block (near the engine steady) there by introducing a cross flow of water?? Now thats an idea!! i might have to scrap my water pump plate
25th Jul, 2006 at 01:44:35pm
mmm, i like the core plug idea, can leave the heater circuit as is then. On 28th Aug, 2011 Kean said:
25th Jul, 2006 at 06:21:43pm
Thinking about this.
27th Jul, 2006 at 11:28:34am
Had a bit of a read & think about this last night,
27th Jul, 2006 at 11:41:19am
A mini isnt a thermo Syphon is it?
AlexF |
27th Jul, 2006 at 02:38:20pm
the pump is not a pump but an ajitator (sorry i cant spell for $£"%) so is a sort of thermo syphon system. Dave intends to keep the standard pump if possible so pumping water into the head via the heater tap is a bad idea as normaly the water comes out of here and this would reverse the flow.
27th Jul, 2006 at 09:01:52pm
few really obvious thoughts that im sure have been thought of ...
27th Jul, 2006 at 09:25:28pm
Suffice to say guys, that everything that could be done has been done, that the radiator / fans are positioned in optimal locations, and that the block was prepared the the same standards I prepare all my engines, and radiator has been flushed through several times.
27th Jul, 2006 at 09:54:39pm
fit extra capacity rad as well Dave
27th Jul, 2006 at 10:01:35pm
yeah - trying to find a motorbike rad/fan combination as we speak!
27th Jul, 2006 at 11:31:01pm
a thin front mounted ??
28th Jul, 2006 at 08:28:20am
could you try a diff rad just to eliminate that poss of stuff being in there so rock solid that flushing wont remove it dave. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Jul, 2006 at 09:57:08am
this is silly but have you tried diferent water pumps ( pressed steel and cast impellers )
28th Jul, 2006 at 10:17:05am
Sorry IF it has been mentioned before (not read all off thread).
Edited by giallofly on 28th Jul, 2006. On 21st Jan, 2011 fastcarl said:
28th Jul, 2006 at 10:35:44am
I've got to electric water pumps, one of the corley conversions place, and one from ebay, neither flow anything like yours jon. Team www.sheepspeed.com Racing
28th Jul, 2006 at 10:39:36am
I am known for my massive squirting capacity.
