| Home > General Chat > QUIZTIME!!!! | |||||||
30th Jul, 2006 at 12:39:02pm
Noone is correct. Keep them coming guys.. I'll try to add some pictures later.
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
31st Jul, 2006 at 03:30:30am
a cam follower smashed and locked the cam up removing teeth from the belt 179hp on 12psi 1293cc of pure A series
31st Jul, 2006 at 04:05:04am
You and Nic were on your way to one of your 'special parties' and realised you weren't weraring any of your trademark fishnets, so removed the belt, pulled it apart,and wove it into a spangly new pair of tights. And there was even enough left over to a gimp ball mask for nic? On 17th Nov, 2014 Tom Fenton said:
1300 Posts Member #: 829 Post Whore essex |
31st Jul, 2006 at 08:24:00pm
Belt going the wrong way 1293 Turbo mini
1st Aug, 2006 at 08:48:47am
On 31/07/2006 03:30:30 RED850 said:
a cam follower smashed and locked the cam up removing teeth from the belt You're correct!!!!! :) To all of you others not being serious, bugger off! So... Why does this happen?`The cam follower had cracked and jammed the crank. Cam is buggered as well :( On 13th Jul, 2012 Ben H said:
1st Aug, 2006 at 10:09:45am
can we see some pictures of both the failed one and the others. the followers are known to wear especialy on high lift cams or high lift rockers. also if they were cheap ones, "you get what you pay for". |
1st Aug, 2006 at 10:32:35am
it did not jam the crank did it? |
1st Aug, 2006 at 11:48:57am
cam.. Crank is good due to the belt snapping. I wonder what would have happened if I had used a chain... On 13th Jul, 2012 Ben H said:
1st Aug, 2006 at 12:02:04pm
It happened while running on the starter didnt it? Then I guess it would have locked up without really making much damage. |
1st Aug, 2006 at 12:03:56pm
It happened while running 5000rpm on 15psi in third. On 13th Jul, 2012 Ben H said:
1st Aug, 2006 at 12:13:22pm
ohh, then it could have gone bang, big time! |
1st Aug, 2006 at 12:15:47pm
that could have been very messy! |
1st Aug, 2006 at 12:21:45pm
sounds like an expensive cam follower!
1st Aug, 2006 at 03:19:21pm
Here are some pictures:
1st Aug, 2006 at 06:45:23pm
Are we not looking at this from the wrong perspective?
1st Aug, 2006 at 07:03:42pm
I change mine every 50 miles
AlexF |
1st Aug, 2006 at 07:39:57pm
i wish dave |
1st Aug, 2006 at 07:44:27pm
LOL
1st Aug, 2006 at 07:46:22pm
oh and belt drive up to 9500 rpm. Now you are dicing with a destroyed engine.
1st Aug, 2006 at 07:52:49pm
its the most my racers engine does before it needs to come out for somthing else
AlexF |
2nd Aug, 2006 at 04:12:55am
what do i win??
2nd Aug, 2006 at 11:56:31am
You won a RHD wooden dash.. BUt I see that you're on the other side of the planet. You nned to come and get it On 13th Jul, 2012 Ben H said:
