Home > General Chat > Techniclutch Verto 30% Upgrade
i just pulled the clutch from my car ,and its got 101 thou 2.59mm approx spring thickness ,this is a lot more than the other verto's iv see with 80 thou springs ,maybe a geniune turbo cover ,although i thought they were only 95 thou ish .unfortunately i cant find any makers name on it yet .
regards
double post !
Edited by robert on 7th Mar, 2007.
triple post !!
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4510
usefull data.
Robert,
What's the OD of the spring?
Some are larger than others. The verto I've fitted to mine is the minispares top rated one at 180mm OD and about 0.100 thick. Most of the others are 170mm ish.
184.2mm
do you think the diameter of the spring will affect the force axel ?
regards
robert.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Robert ... where did you get that one from, 101 thick fingers .... should work well ...
it was on the turbo engine when i bought it in 97, its a f reg engine 87 i think .
bit more info , the 101 thou one has a pale blue dab of paint on it ,and the 96 thou one has a green marker .
