| Home > General Chat > Windage Tray | |||||||
23rd Oct, 2006 at 08:10:56pm
that is as low as the gearset will alow
Edited by Sprocket on 23rd Oct, 2006. On 26th Oct, 2004 TurboDave16v said:
24th Oct, 2006 at 08:07:54am
What a wanker on Minifity.. I wouldn't fit that in any engine ever. It looks shite, and also, the child making them is not that very techical minded. Id fork out £59 for the Minimania one any day.
24th Oct, 2006 at 08:40:45am
I would rather buy KC's than the one made by minimania. The minimania version is mounted by drilling 3 holes in the casing, while KC's version needs no new holes. At least that is what he has written on the minimania board. Edited by miniminor63 on 24th Oct, 2006. |
24th Oct, 2006 at 11:29:38am
KC's one:
24th Oct, 2006 at 05:38:05pm
Funnily enough the ones I make are very similar to KCs
I seriously doubt it! |
24th Oct, 2006 at 05:56:52pm
show us then ,could sa ve me a job,
24th Oct, 2006 at 07:13:21pm
if there not to expensive il have one to make numbers up! price dependant no longer a series, but still 1.3 turbo.
24th Oct, 2006 at 07:33:53pm
I'll be interested Sprocket, I was inteding to get one from KC but they look shiter than I expected,
24th Oct, 2006 at 11:03:13pm
Interesting stuff!!
24th Oct, 2006 at 11:14:08pm
i just reread the above, i didn't think about the fixings,
25th Oct, 2006 at 07:46:15am
I have made on for myself, that is pretty similar to the minimania style and fits a remote box. I have mounted that by drilling and tapping two holes, one in each corner of the box on the same side as the mainshaft. Then I have mounted it to the bolt fastening the CPU. Thats all and the aluminium is pretty thin (1.2 mm comes to mind), still it has been okay for the last two years in my 1191 cc engine.
Edited by miniminor63 on 25th Oct, 2006. |
25th Oct, 2006 at 08:14:06am
On 24th of Oct, 2006 at 07:33pm mini13 said:
I'll be interested Sprocket, I was inteding to get one from KC but they look shiter than I expected, mind you still good for a tenner. That's what's so genious. Simple and effective. Why have a fancy overenineered plate down there? It works. On 13th Jul, 2012 Ben H said:
25th Oct, 2006 at 08:20:18am
I agree on that, I can not see a point with a plate covering the whole box really, eventhough I have made mine like that.... |
25th Oct, 2006 at 09:03:59am
What can i say, i'm a magpie, it has to be shiiney and nice even if i cant see it! On 28th Aug, 2011 Kean said:
25th Oct, 2006 at 09:21:02am
You're entitled to an opinion! On 13th Jul, 2012 Ben H said:
1425 Posts Member #: 690 Post Whore Norfolk |
25th Oct, 2006 at 09:26:23am
I've tried one of the mini mania ones - its sitting in my cupboard in the garage as I couldn't get the thing to fit for love nor money when racing to finish the K16 motor earlier this year- it wouldn't clear the con rod bolts on std stroke 1275 crank - even when they were down to + 1 thread out of nut - wasn't prepared to spend any more time frigging around with it.
If Carling made Mini engines
25th Oct, 2006 at 09:33:56am
I can see the theory behind this but a couple of concerns, surely the piston reley on oil splash for cooling plus the cam would surely suffer due to less lube.
25th Oct, 2006 at 09:41:14am
I would have thought that it would do okay without, as then it would be like the inline A series. anyway, I think that undercrown jets and a crossdrilled cam will take care of these problems. |
25th Oct, 2006 at 09:49:47am
I know piper supply cross drilled cams, they seem to be bore through it's length and an oil hole on the low side of the lobe.
25th Oct, 2006 at 09:52:59am
Double post...
25th Oct, 2006 at 10:04:19am
you are correct, they are drilled like that, I have one in my engine |
25th Oct, 2006 at 10:05:47am
I think I'd rather have a bit less oil there (which is ok Judging By inline A's) rather than the posibility of unfiltered oil being thrown up by the box onto the cam and bores.
25th Oct, 2006 at 08:09:39pm
On 25th of Oct, 2006 at 09:26am johnK said:
I've tried one of the mini mania ones - its sitting in my cupboard in the garage as I couldn't get the thing to fit for love nor money when racing to finish the K16 motor earlier this year- it wouldn't clear the con rod bolts on std stroke 1275 crank - even when they were down to + 1 thread out of nut - wasn't prepared to spend any more time frigging around with it. Sprocket - if you want this one as a template of how not to do it pm me your address and I'll send it down John PM sent
