| Home > A-Series EFI / Injection > Inlet Manifold Design | |||||||
16th May, 2007 at 08:39:29am
hmmm i see... looks like side by side on the top axel maybe at a 10 ish degre angle to each other ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th May, 2007 at 11:32:01am
I'm now on version 11 of this!
Edited by Paul S on 18th May, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
18th May, 2007 at 12:24:30pm
That looks interesting however I'd be tempted to look at putting the upper, currently unused, bosses at a slight angle in such a way as the spray patterns from a pair of injectors would, under static conditions, intersect somewhere in the middle of the runner.
26th May, 2007 at 08:35:53pm
I've started cutting metal, so any further thoughts would be appreciated. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
26th May, 2007 at 09:15:37pm
If you could get injectors with a spray pattern similar to the injector on the right at http://www.mmcompsys.com/download_zone/4_f...co_spray_01.pdf
27th May, 2007 at 11:26:32am
Good link Jean...
27th May, 2007 at 12:21:46pm
Thanks for the comments.
Edited by Paul S on 27th May, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th May, 2007 at 01:33:54pm
Right, Version 12 signed off for manufacture. Edited by Paul S on 27th May, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th May, 2007 at 04:11:04pm
That looks great! I'm looking forward to see how this will work.
27th May, 2007 at 05:24:36pm
On 27th of May, 2007 at 04:11pm jbelanger said:
That looks great! I'm looking forward to see how this will work. This version has really good aim for both injectors and the difference in distance is minimal. That should give great results and be much more straightforward for tuning when going from unstaged to staged injectors. Jean I'm glad you said that because I've cut the flanges and runners this afternoon!
Turn up the bosses tomorrow. I should be sunning myself somewhere but we are getting bad weather here, so I might as well get on with it. Edited by Paul S on 27th May, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
28th May, 2007 at 11:59:23am
Axel ...... not a critism just a question ... is there room for a double fuel rail back there?
28th May, 2007 at 12:19:18pm
On 28th of May, 2007 at 11:59am RogerM said:
Axel ...... not a critism just a question ... is there room for a double fuel rail back there? Just, there is about 10mm clearance with the bulkhead, but the turbo should stop it moving that far back. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
28th May, 2007 at 12:57:01pm
you could allways run a pipe to each inj like this axel .
28th May, 2007 at 02:23:31pm
I'm going to machine some of this aeromotive fuel rail:
29th May, 2007 at 03:43:16pm
That's a lot of wonga!
29th May, 2007 at 04:48:05pm
And it is too big! 5/8" ID.
29th May, 2007 at 04:58:25pm
A bit of progress:
29th May, 2007 at 05:32:54pm
Out of interest how high did you set the tig to to weld that? On 28th Aug, 2011 Kean said:
29th May, 2007 at 05:40:21pm
On 29th of May, 2007 at 05:32pm mini13 said:
Out of interest how high did you set the tig to to weld that? About 90 amps. Using a 1.5mm tungsten and a 5mm cup. The welding is not great but it's getting better. The one of the left is much better. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th May, 2007 at 06:01:32pm
Thanks,
30th May, 2007 at 06:16:47pm
A bit more done today:
30th May, 2007 at 06:42:49pm
Silly question 1 - is this going to fit????
30th May, 2007 at 06:47:35pm
I think the angle of the shot exagerates the size of the plenum.
Edited by Paul S on 30th May, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
30th May, 2007 at 07:16:45pm
neat hole cutting and fab axel , um do you think that maybe no 1 inlet will get a bit of velocity induced lower input than no 2 ,with 1 being so close to the feed pipe ? just a thought,a cone inlet woiuld help .
30th May, 2007 at 07:25:45pm
On 30th of May, 2007 at 07:16pm robert said:
neat hole cutting and fab axel , um do you think that maybe no 1 inlet will get a bit of velocity induced lower input than no 2 ,with 1 being so close to the feed pipe ? just a thought,a cone inlet woiuld help . Yes, it's not ideal, but space is a problem. Given that I need to get the inlet pipe between the rocker cover and servo, I've had to cut down the distance from the end plate to the runner. There is just enough space to get a 2" 90deg bend on the end, no room for a cone. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
