Home > General Chat > O/T BUGGER. Opinions please lads?
On 1st of Jul, 2007 at 11:14am Nic said:
careful with those rpms tom, you dont want to throw a rod through the block...
Can you actually break a diesel? a couple of my mates have got diesels and cane the crap out of them, still run sweet as a nut. I don't know anyone who has either.
Edited by minimole23 on 1st Jul, 2007.
in my old work van i hit the limiter in 1st, 2nd, 3rd, and 4th regularly over 65 000miles and i never had a problem with bits popping
(though i heard on the grape vine that the next person to have it didnt have it long before it went into the garage...)
On 21st of Jun, 2007 at 05:04pm MrTurbo said:
I my memory serves me right these engines are fitted with an exhaust gas recirculation valve. (for emission reasons....)
If this valve is not operating correctly i think it could cause the problem you describe. Do a search on one of the vw/volvo (old v70 uses the same engine) sites. There is a lot of info on these valves, especially since people are blocking of this valve to get rid of the blue smoke when accelerating hard and gain a few hp
No the Volvo uses the I5 engine, not V6.
Also, check your camshafts every once in a while. They're made of butter and are a fortune. + there are four of the shit buggers. My mum's got an A6 with the same engine. Just changed the diesel pump at £1600. Will not be buying such engine again. Have seen som many gearbox failures (6-speed) and camshaft failures now.
