| Home > Show Us Yours! > B18 vtec build | |||||||
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
22nd Jul, 2007 at 09:56:07pm
Is that a jig for drilling holes for the k1100 head? looks good. What head studs do they use? the std K1100 studs? Back once again like a renegade master |
![]() 646 Posts Member #: 1826 Post Whore Maldon Essex |
23rd Jul, 2007 at 07:35:57pm
yep certainly is, im going to be measureing it then making a program on one of the cnc mills at work.
3rd Aug, 2007 at 09:31:27pm
i have now stripped the head fully and deburred all the sharp edges on it. i have started making up the little bungs to be welded in, once this is done i will be getting the grinder out on it.
230 Posts Member #: 1131 Senior Member |
4th Aug, 2007 at 12:29:36pm
looking good mate |
5th Aug, 2007 at 12:00:57pm
Andy what metal are you using to plug your block? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 140 Posts Member #: 1367 Advanced Member Cape Town, South Africa |
5th Aug, 2007 at 12:34:58pm
Hopefully he'll be using cast threaded bungs so they have the same expansion index as the engine block |
5th Aug, 2007 at 12:39:11pm
i was just going to use some cast iron bar like SC recommend
5th Aug, 2007 at 02:09:09pm
Where are you getting the bar from, all my local suppliers are shite, they recon they can't get hold of any!!
5th Aug, 2007 at 02:33:01pm
i hadnt thought of using threaded bungs, i was just going to go with the interferance fit plugs.
6th Aug, 2007 at 01:13:01pm
Ah makes things easier then..lol
Edited by matty on 13th Aug, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
13th Aug, 2007 at 07:22:40pm
i have got my upper bulkhead now.
13th Aug, 2007 at 10:41:26pm
Not exactly true! You did accurate cardboard templates to work to, top job. So 50/50 on this one Andy!
On 19th Jan, 2010 wil_h said:
16th Aug, 2007 at 10:24:27am
Be careful using cast iron bar for the plugs.
16th Aug, 2007 at 08:17:55pm
thats i good bit of info there. we have got loads of EN16 bar at work so i will be able to do that!
16th Aug, 2007 at 08:40:47pm
what actually holds the block sealing plugs in , ,and stops it coming out if you have to tap into it ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Aug, 2007 at 12:52:56am
Make them so they don't fit ..... get them really cold, the block really hot and put them together ..... in there for life!!
17th Aug, 2007 at 08:26:31am
So you wouldn't consider pluging the block using tapered threaded inserts then, with a dollop of 620 locktite?
11 Posts Member #: 1799 Member Lincoln |
17th Aug, 2007 at 10:09:13am
Andy/Roger M - what diameter hole and plug would you use? |
17th Aug, 2007 at 11:14:32am
Matt, nothing wrong with threaded taper plugs ...... just have to find them and I've drawn a blank in my searches!
17th Aug, 2007 at 12:09:22pm
If using threaded plugs, loctited in, why do they need to be tapered? |
17th Aug, 2007 at 12:51:06pm
Sorry should have typd a bit more, take the old stud hole as an example.
17th Aug, 2007 at 01:06:32pm
The reason for the taper is because the holes you are blocking are galleries (no solid ends) so there is no real indication that the plug has gone up tight. In my experience a taper fitting always tends to seal alot better aswell. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1425 Posts Member #: 690 Post Whore Norfolk |
17th Aug, 2007 at 01:15:02pm
Andy - nice to see you are getting on wel lwith it
If Carling made Mini engines
17th Aug, 2007 at 02:14:52pm
On 17th of Aug, 2007 at 12:52am RogerM said:
Make them so they don't fit ..... get them really cold, the block really hot and put them together ..... in there for life!! An A series block fits into a large domestic oven (and Candice thinks I bought a range because I enjoy cooking ..... actually I only really enjoy eating and the cooking thing is just a means to an end ) and a domestic freezer can get the plugs down to about -10 .... just about enough of a diffference at the required diameters that a light hammer fit becomes permenant.ah i see thanks roger , i was thinking of the threaded plug loctited in too ,but not tapered ,and it semed a bit impermanent . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Aug, 2007 at 05:25:10pm
roger thats the exact method i will be using, we do quite a lot of stuff like this at work so i can get any help i need. and we have a big oven the block will fit in.
