| Home > MS Trials & Testing > Dual Wideband Datalog | |||||||
2nd Dec, 2007 at 02:46:36pm
Latest log attached.
Edited by Paul S on 2nd Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Dec, 2007 at 05:19:58pm
I think that part of the AFR difference may be related to wall wetting. Most of the fuel evaporating from the manifold wall will go to the inner cylinders because of charge stealing. At low RPM, there is more time for fuel to evaporate so the AFR difference will be bigger as shown in the log. At higher RPM, the difference becomes less because there's less wall wetting.
2nd Dec, 2007 at 05:34:52pm
It could also be due to the inner cylinders getting more fuel at low rpm due to the charge stealing.
2nd Dec, 2007 at 05:49:42pm
This is the last bit of full throttle and the engine should have been well and trully cooking.
62 Posts Member #: 1515 Advanced Member |
2nd Dec, 2007 at 09:31:13pm
Ignore my last email then as you had worked that out :)
2nd Dec, 2007 at 09:40:54pm
On 1st of Dec, 2007 at 02:50pm mini13 said:
also, on the subject of datalogging... has anyone seen this lcd touchscreen display for megasquit? it will aparantly datalog onto a USB flash drive before too long. Also the gauges will display as graphs so wo can see what has just happened a bit like a mini datalog. http://lcdash.wikispaces.com/ Yeah. know where there is one for sale that has been nicely packaged up. Being brutally honest, unless you want the bling, a palm pilot is just as good and almost free. |
2nd Dec, 2007 at 10:14:00pm
Charge stealing with a carb shouldn't happen. It does happen due to either wall wetting or fuel inertia. And these 2 effects will affect the AFR difference in different directions.
2nd Dec, 2007 at 11:50:33pm
could you not set the lc1 up to say put out exactly 2.5v no matter what the AFR is, and then see what logworks records through the aux-box? i.e.e see that it is actually 2.5v?
Edited by evolotion on 2nd Dec, 2007. turbo 16v k-series 11.9@118.9 :)
3rd Dec, 2007 at 08:41:36am
I have a gauge on the LC-1 as well as feeding 0-5v into the Aux Box.
3rd Dec, 2007 at 11:46:12am
damn right paul good attitude! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Dec, 2007 at 01:46:09pm
What is the customer support for the innovative products like? Isn't this something they should be assisting with?
3rd Dec, 2007 at 02:22:51pm
On 3rd of Dec, 2007 at 01:46pm TurboDave said:
What is the customer support for the innovative products like? Isn't this something they should be assisting with? There is a well attended forum on the Innovate site, but the readings may be right. It's just my confidence in the readings is low at the moment. On 3rd of Dec, 2007 at 01:46pm TurboDave said:
Is there any way of running both sensors in the aux box - or maybe a third sensor that is - so you have one main output for the main display, and a visual for the two others?. The aux box is an extension of the LM-1. The LM-1 is the controller for the sensor and will not work without the sensor directly connected. I could feed the 0-5v output from the LM-1 back into the Aux Box but no point really. On 3rd of Dec, 2007 at 01:46pm TurboDave said:
Alternativly - is it possible that the slope of the curve of the output is not constant between the two? I guess swapping them over will reveaql this for sure. I suspect that if there is a problem, it will be something to do with the conversion of the data. The LC-1 measures Lambda, calculates AFR, then converts it to a voltage signal. Then I convert it back to AFR by using a simple multiplier in Excel. Maybe this is wrong. When the serial cables finally arrive, I will be able to log the LC-1 output without the Aux Box and any calcs. If there is something wrong in the conversion, that will eliminate that. My money is on simple instrument error, possible due to calibration. The next test will clarify that. Edited by Paul S on 3rd Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Dec, 2007 at 08:10:06pm
Paul,
3rd Dec, 2007 at 08:52:05pm
On 3rd of Dec, 2007 at 08:10pm TurboDave said:
Paul, How about an overview of how you use the LM1 and LC1 together? I've not understood - and can't easilly find - what it is that is actually recording the data. Is it done inside of the LM1? If so - How does the LM1 interpret between the two channels as far as the display and output is concerned? And what of the other sensors - what is the actual need of the aux box at this time as I thought you could tap the extra sensors into the LM1 as it was (it lists "Up to 6 Channels of data logging" on the website for the LM1). Or is it needed to get the extra LC1 input into the LM1? The LC-1 is a controller for a wideband sensor with two analogue outputs and serial ports for daisychaining ala RS485. The LM-1 is also a controller but is portable and has a display. The LM-1 can also log an additional 5 channels of data. However these need to be in a 0-5v signal. The Aux Box is a convenient way of creating the 0-5v signals. So I've connected a tach signal to read RPM and it has an on-board MAP sensor. These are then converted to 0-5v signals by the Aux Box which is connected to the LM-1. So that I can also log the LC-1 data, I've connected one of the analogue ouputs to one of the Aux Box channels. The laptop connects to the LM-1 serial port and then reads all the data from one point. The LM-1 can do the recording itself and is then downloaded. On 3rd of Dec, 2007 at 08:10pm TurboDave said:
Incidentally... When i spoke with innovative a loooong time ago regarding this kind of stuff for the A-series, they said the best way to go was the DL32 and two LC1's as this had the best sampling rate and bought all data in at the same time. I never looked much further into this though as the AEM sensors appeared at a great price, and I figured i could log the outputs from these if i so needed. Looks like they do now do a kit for the DL32 and a few sensors - aimed at v8 guys for a sensor in each 'bank' http://www.innovatemotorsports.com/xcart/p...41&cat=0&page=1 Eventually I will just want the single LC-1 fitted to the car. It seemed a bit expensive to buy an additional LC-1 and a DL32 to use once. Not much change from £500 for the DL32 and additional LC-1. I've spent a small fortune as it is. The LM-1, being portable can easily be switched between cars. For example, I used it to set up Sturgeo's car when we fitted a 12G295, HIF38, LCB etc. Within two hours we had the mixture spot on and no need for a rolling road. I'm doing the same job on Axel's 30 soon so the LM-1 will have a lot of use. The LC-1 is only really suitable for a permanent install. 6 core cable, calibration switch, LED etc. Whereas the LM-1 only has a power lead with a ciggie lighter plug and the sensor. On 3rd of Dec, 2007 at 08:10pm TurboDave said:
As regards the sampling rate - what is the sample rate of the raw data out of the LM1? I know it says 12bits / sec on the site - but I'm guessing the raw data has a significnatly higher resolution??? It reads and logs the data at 12 times a second rather than 12 bits/sec. Edited by Paul S on 3rd Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Dec, 2007 at 09:15:28pm
3rd Dec, 2007 at 10:07:17pm
Would you agree that it is reasonable to expect that the LC-1 and LM-1 should give comparable readings?
3rd Dec, 2007 at 10:42:45pm
What is the customer support for the innovative products like? Isn't this something they should be assisting with? [biased bit] As an innovate dealer I like to think I support everything I have supplied, and will happily test check and recalibrate any innovate product FOC [/biased bit] Internally the LC-1 and LM-1 are very very similar, so if calibrated to their respective sensors should give exactly the same output. As you can daisy chain them at a serial level you can avoid any question of grounding issues and view the output using logworks on a laptop. This is a very easy way of seeing if the difference is real or not. A differnce of 2 on the AFR is 0.5V which is quite a lot of ground offset, but not impossible. I wish I had time to code, as then I would do a palm pilot port for the innovate (techedge has that). which would make logging a whole heap easier. |
3rd Dec, 2007 at 11:31:14pm
Interesting stuff Paul, watching with interest!
4th Dec, 2007 at 09:32:04am
On 3rd of Dec, 2007 at 10:42pm bill shurvinton said:
[biased bit] As an innovate dealer I like to think I support everything I have supplied, and will happily test check and recalibrate any innovate product FOC [/biased bit] I did not know that you were an Innovate dealer. You missed out on some extra business. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Dec, 2007 at 02:09:35pm
Well, I just found out that the log output on the AEM gauges suck big time.... So my plan to simply log the outputs from these on my maxQ unit is not going to be of any use.
4th Dec, 2007 at 02:20:51pm
The serial leads turned up this morning, so I'll be able to daisychain the whole lot and not rely on the aux box for the LC-1 input. Although I will run them both at the same time to start with just to check the accuracy.
4th Dec, 2007 at 02:39:23pm
The serial port jobbies are definately the way to go.
4th Dec, 2007 at 08:46:31pm
LOL at Daves Sig On 26th Oct, 2004 TurboDave16v said:
4th Dec, 2007 at 09:11:28pm
[biased bit] As an innovate dealer I like to think I support everything I have supplied, and will happily test check and recalibrate any innovate product FOC [/biased bit] I did not know that you were an Innovate dealer. You missed out on some extra business. Didn't want to be overly pushy seen as you gave me an awful lot of your hard earned as it was :). Anyway my own fault for not having websites or special MS+WB packages for minis sorted out. |
6th Dec, 2007 at 01:23:20pm
I just saw across this on minimania.
