| Home > Show Us Yours! > Midget Update | |||||||
21st Mar, 2009 at 07:38:36am
On 20th Mar, 2009 Nic said:
I really really realllllllllllllly would like an MG midget at the moment (I had to be careful how i phrased that then) yep me to thanks to this thread
Yes i moved to the darkside |
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
21st Mar, 2009 at 10:04:41am
With no screen the wind noise drowns the gear whine.I have wondered about an english axle,but I'd want to 4 link it,turrets,coilovers,mumford link.........Maybe when this one breaks. 'Where does the engine go?' |
21st Mar, 2009 at 10:09:14am
Rob,I gave p on the lip seal and refitted the standard setup-so far so good.
30th Mar, 2009 at 08:10:29am
Awshit,tempting fate to talk about axles,the diff.let go yesterday.Same failure mode as before I think,the rollpin holding the planet shaft falls out,the shaft then emerges,biting lumps off the carrier as it goes,then no drive. 'Where does the engine go?' |
30th Mar, 2009 at 01:54:47pm
Steve, I have a 3.9 diff I,m getting rid of (got 3.7 in the beast now).Its not completely silent but how many are ?
30th Mar, 2009 at 11:52:48pm
On 21st Mar, 2009 tadge44 said:
Rob, by english axle do you mean the Ford one ?. Yep Ford axle. As an side mine has started leaking oil again, still I managed a month with out a leak, is that a record? Isambard Kingdom Brunel said:
326 Posts Member #: 1323 Senior Member |
31st Mar, 2009 at 12:09:09am
you can stop the diff planet gear shaft falling out by fitting a piece of thin plate [ 1mm] over the ends of the shaft , fixed with small bolts tapped into the diff . then if the pin shears [ usually cos the planet gears have picked up on the shaft ] all that happens is the shaft spins as well , but cant fall out . [ we do this mod with trials diffs. cos not allowed to use limo's ]
31st Mar, 2009 at 07:47:59am
Thanks Carl,that sounds a good mod.I fancy the Quaife atb,but wondered about its strength.
31st Mar, 2009 at 11:37:53am
you won't break the quaife , 1/2 shafts , even uprated ones , will break first ! |
8th Apr, 2009 at 04:25:00pm
Just talked to the local quaife and tranX dealer.For rear wheel drive he strongly recommends the tranX.Any thoughts on this?(sorry I know its rwd 'Where does the engine go?' |
8th Apr, 2009 at 08:00:59pm
I would go for the Quaife , esp if mostly road use
8th Apr, 2009 at 08:41:57pm
Thanks,Carl,will think some more on this. 'Where does the engine go?' |
9th Apr, 2009 at 12:32:43am
Any indication of costs for the Quaife,please ? Or the ratios available ? |
9th Apr, 2009 at 11:42:13am
Hi Dave,about £550 plus vat.you fit your own cwp and if done professionally with new bearings etc. about £200 for fitting.There are no alternative internals for the quaife,unlike the plate types. 'Where does the engine go?' |
9th Apr, 2009 at 02:38:45pm
Thanks for that Steve -bit too rich for me I,m afraid -will just have to keep on changing diffs -will be down to my 4.55,s soon ! |
9th Apr, 2009 at 04:07:21pm
Go on the midget and sprite club site,sales/wants,usually diffs on there for around £50. 'Where does the engine go?' |
9th Apr, 2009 at 07:29:16pm
Thanks Steve -following up a couple of leads on there. |
26th Apr, 2009 at 06:56:15pm
On 20th Mar, 2009 Rob H said:
Got to say I've not driven a Midge with a SC box, but I had driven one with a Type 9 and it's a nice conversion, that said I've still got the old for speed in mine and it'll probably stay that way unless I break the box. Spoken too soon today mine developed a nasty habit of jumping out of second gear. Isambard Kingdom Brunel said:
26th Apr, 2009 at 07:02:22pm
I really really realllllllllllllly would like an MG midget at the moment (I had to be careful how i phrased that then) I'd really really realllllllllllllly would like to see you trying to get in a Midge ![]() On 21st Mar, 2009 Nic said:
I reckon I could do it Hum, it's almost worth driving up to Hereford. Isambard Kingdom Brunel said:
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
26th Apr, 2009 at 07:05:15pm
I really really realllllllllllllly would like an MG midget at the moment (I had to be careful how i phrased that then) Could have brought mine! lol On 15th Jul, 2009 fastcarl said:
the pissed up clown stood back up, did a twirl and left bollock naked, |
26th Apr, 2009 at 08:27:31pm
Hi Rob,Midget and sprite site,sales/wants usually has a box for sale....... 'Where does the engine go?' |
1st May, 2009 at 09:15:49pm
Finally sorted various software/connection issues and got the beast set up at Mech motorsport.Stopped at 16psi boost (chicken!) and pulled 156bhp and 149lbf.ft so hope to use it now for the Summer.
1st May, 2009 at 09:24:39pm
congrats mate. some very good numbers there! |
2nd May, 2009 at 01:52:55am
Good going!! |
2nd May, 2009 at 07:56:13am
I really really realllllllllllllly would like an MG midget at the moment (I had to be careful how i phrased that then) Could have brought mine! lol I actually tried to convince mum that she needed it when it came up for sale. On 7th Oct, 2010 5haneJ said:
