| Home > General Chat > Any thoughts/comments on my proposed spec? | |||||||
29th Sep, 2008 at 11:59:47am
how come you believe the duplex chain is a waste? If something is worth doing, it's worth doing half of. |
29th Sep, 2008 at 12:42:39pm
On 29th Sep, 2008 minimadmotorman said: You might as well go the extra and fit the adjustable duplex chain kit.
how come you believe the duplex chain is a waste? I have one engine with the standard chain and one with the vernier adjustable setup. It just means you can tune the engine just so if you take the fancy to. One component you missed was a new oil pump and I would recommend fitting a secondary magnetic pick-up in the back of the gear box. After seeing the crap it catches that gets past the screen I will be fitting one of these every time! Edited by Mr Joshua on 29th Sep, 2008. Own the day
29th Sep, 2008 at 02:02:37pm
duplex isnt a waste imo "Turbo's make torque, and torque makes fun"
29th Sep, 2008 at 04:19:35pm
it's a waste because it'll give no more on a turbocharged a serie than a simple one.then I never got any troubles with the std set up, just use keys to adjust lca. |
29th Sep, 2008 at 06:48:08pm
give no more what fab?
29th Sep, 2008 at 07:46:04pm
I think Fabrice is saying he feels the duplex chain is OTT.
Edited by turbodave16v on 29th Sep, 2008. On 17th Nov, 2014 Tom Fenton said:
30th Sep, 2008 at 09:24:10am
so add a new set of followers obviously and a new oil pump and see how the funds go when it comes to the timing chain. If something is worth doing, it's worth doing half of. |
2nd Oct, 2008 at 02:44:05pm
any thoughts what sort or nana's and curlies this should do on 12psi?
2nd Oct, 2008 at 07:09:44pm
Around 140hp or so on 12psi i would think. PM me if your intrested in a head mate. :) |
3rd Oct, 2008 at 08:15:42am
will do when i have the money. ploughing all my money into getting the shell sorted a holiday with the missus and crimbo at the moment If something is worth doing, it's worth doing half of. |
3rd Oct, 2008 at 03:10:05pm
Eeep!
10th Mar, 2009 at 04:17:33pm
Just had a little look back over this post. Would seem that my spec has changed somewhat over the last few months. Edited by John on 12th May, 2009. If something is worth doing, it's worth doing half of. |
