Home > Show Us Yours! > More Cake for The 998T
well done Wil, looks good, not sure on your quote about the round holes, it's just most people aren't as slap happy with the tin snips as your good self ;p *wink*
lol, i was just about to say it looks half decent from the side repeaters back, UNTIL i saw the other piccies,ha ha,
T cut and all that bollocks,lol.
carl
Ric
Member #: 36
Basingstoke
absolutely love it! Bet it suprises a few people!
That looks brilliant!
I wonder if this will ever get the 'turbo shed' treatment.
Sir Yun
Member #: 1592
Smart Guy!
you don't need frigging chrome when you have ducktape!
if steel rusts does it get heavier before it falls off ?
alpa
Member #: 2093
Grenoble, France
wil_h, I could not find a detailed description of your mods, could you point at please.
So it's an std 998 with a 1300 head, std valves and 7psi, isn't it ? Which camshaft ?
My VNT15 refuses to make less than 130kpa at 5000RPM, so I'm still wondering about the safe limit without IC. It would be nice to hide the IC somewhere.
Edited by alpa on 12th Jun, 2008.
This is the build thread, I think it answers your questions. I currently run a little over 0.5 bar (according to the gauge) I'd be pretty happy to run this psi with no IC and 9.3:1 CR. http://www.turbo-mini.com/62147.html
alpa
Member #: 2093
Grenoble, France
I remember now, I've already seen it.
Your IC was actually rather inefficient. I think using a small well exposed should work as well.
i was under the impression rs ics were very good?
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Awesome car! A perfect example of form following function
On 30th Apr, 2010 Rod S said:
Gary's description is best
nice wil, stealth look for sure
i will have to get shut of the holes now *laughing*
I assume that you mean the posisioning, as in behind the bonnet in zero airflow.
Cheers for all the comments guys
alpa
Member #: 2093
Grenoble, France
Of course. This shows (once again with all stock badly exposed IC, even on 2L 305hp Maserati Ghibli II) there is a huge margin. Perhaps a fan controlled by the temperature of the air exiting the compressor would be enough. Or even installing the IC in parallel to the water rad.
Edited by alpa on 13th Jun, 2008.
