| Home > 998cc > Finally made a start on the engine | |||||||
11th Nov, 2008 at 10:06:53am
On 11th Nov, 2008 matty said:
Sigged!
On 10th Nov, 2008 joeybaby83 said:
paul your a dream boat! ill pm you Good. I was still getting embarrassed about your previous sig. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Dec, 2008 at 07:04:21pm
made a bit more slow progress today, fighting off hangover plus man flu so got achey joints and thick head etc, but still got a few milestones out of the way
Edited by joeybaby83 on 6th Dec, 2008. "Turbo's make torque, and torque makes fun"
6th Dec, 2008 at 07:19:25pm
nice solution to the thrust retention. :)
6th Dec, 2008 at 07:25:25pm
Are you sure that you need under crown cooling on the 998?
6th Dec, 2008 at 07:32:20pm
possibly not, ive never ever seen a 998 little end!!
6th Dec, 2008 at 07:37:03pm
The spray hole is on the big end, pointing to the underside of the piston. There is a corresponding hole in the bearing shells. It must get a good dose once a rev. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Dec, 2008 at 08:34:25pm
The hole can be seen here:
6th Dec, 2008 at 08:42:25pm
do all small bore roads have this? i cant believe i havent noticed it before...? "Turbo's make torque, and torque makes fun"
6th Dec, 2008 at 08:44:13pm
On 6th Dec, 2008 joeybaby83 said:
do all small bore roads have this? i cant believe i havent noticed it before...? I believe so. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Dec, 2008 at 10:30:15pm
I believe that this is for lubricating the fully floating wrist pin. This has got a lubricating hole at 12 o clock.
6th Dec, 2008 at 10:33:33pm
My early A+ ones from an engine with fully floating pins do.
6th Dec, 2008 at 10:35:41pm
On 6th Dec, 2008 Paul S said:
My early A+ ones from an engine with fully floating pins do. What's the difference between an early A+ with floating pin and an A rod? On 13th Jul, 2012 Ben H said:
6th Dec, 2008 at 10:36:59pm
On 6th Dec, 2008 Vegard said:
What's the difference between an early A+ with floating pin and an A rod? Very little I expect. Most likely identical. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
6th Dec, 2008 at 10:59:23pm
What's the difference between an early A+ with floating pin and an A rod? Very little I expect. Most likely identical. Sounds darn plausible. Exhausting stock while the new stuff is implemented. On 13th Jul, 2012 Ben H said:
444 Posts Member #: 2885 Senior Member |
17th Dec, 2008 at 12:29:32am
I have A's, circlipped, 3-ring slippers with this oil jet hole.
17th Dec, 2008 at 08:12:33am
On 17th Dec, 2008 hario said:
I have A's, circlipped, 3-ring slippers with this oil jet hole. Notice lube hole in little-end is pointing up suggesting that oil hits the crown and rains down onto and into little end..? Yes, I guess this is the reason. On 13th Jul, 2012 Ben H said:
9th Nov, 2009 at 01:39:40pm
the 998 turbo motor is on the back burner at the min, but slowly getting the bits sorted, some goodies arrived today
9th Nov, 2009 at 01:45:21pm
On 9th Nov, 2009 joeybaby83 said:
parts wise, all thats needed now is a bush to convert the 275 drops to 998, ill get that made locally when i can be arsed! Swifty sell one for about a tenner. It's on their site. It's just listed as a 998 floating bush but the OD is the size of the ID of a 1275 primary Good to see progress on this engine. I look forward to seeing it come together On 12th Nov, 2009 Paul S said:
Gary's description is best |
9th Nov, 2009 at 01:50:04pm
i had a word on him at the autosport show, and he thought that those bushes would only fit his inhouse drops witht he circlip retention?
9th Nov, 2009 at 01:54:03pm
You could be right. I bought one assuming it was a floating bush for a standard 998 but the OD was too big. I guessed it was 1275 size but would make more sense if it fitted his drops given the part description on his site. I never tried it in a 1275 primary On 12th Nov, 2009 Paul S said:
9th Nov, 2009 at 05:36:57pm
do you still have it? want me to try it for you :)
9th Nov, 2009 at 06:40:26pm
do you still have it? want me to try it for you :) Unfortunately we turnde it down in a lathe to act as a standard floating bush for a 998 primary on a 998 crank. Otherwise you would be welcome to it On 12th Nov, 2009 Paul S said:
14th Nov, 2009 at 07:44:54pm
Well a little more progress
15th Nov, 2009 at 01:25:26pm
Great to see progress. It was Joe (mini13) who mentioned the idea for the pressure relief rerouting. I cant remember what thread it was in though On 12th Nov, 2009 Paul S said:
16th Nov, 2009 at 08:09:48pm
When i did mine i just did it straight out the side of the block so it will hit the transfer case and dribble down onto the middle gear (ish), IIRC there is a fin below my hole that will direct it onto the gear
