Home > Technical Chat > GT2056
Given Roberts performance on the rolling road at nearly 190hp with the GT17, then that would be my choice for say up to 20 psi boost.
The GT2056 should start to deliver the goods above 200hp.
Thanks Wil, more food for thought. TBH I would like a GT17 for the 1310 but I haven't found a reasonably priced good condition one yet.
fastclown
Member #: 5067
I came across a Garrett turbo with a .48 compressor and a .63 turbine. My goal would be stock Metro turbo compression and 8lbs of boost. I also plan to place the turbo on top of the flywheel housing, so the exhaust runner would be longer than normal. Comments on what this turbo would do...???
No idea without more information.
fastclown
Member #: 5067
I was thinking that it came down to A/R sizes. This seems to be a smaller compressor and bigger turbine than what I've read about. How do I chose? What are the sizes on the stock T3; I have a Mini with that in it.
What other info do I need? Any help would be very much appreciated.
Mike Guido
alpa
Member #: 2093
Grenoble, France
So Paul did you try this turbo ? How about oil-only core ? I'm also looking for the diesel stuff.
Not yet.
I'll probably be working on the downpipe later today.
Nick has got 190+ hp out of his though.
Sounds like a T25 off a 200sx maybe. Better to start a new thread with these questions. .63 ex A/R is a bit big really.
TurboHarry
Member #: 115
Austria, near Vienna
Hi Guys,
I am running exact this turbo on my K engine conversion for 2 years now - never missed the cooling water stuff....*smiley*
Boost starts at 3500rpm....
Harry
Bimmer Twinky headed and turboed A-Series:
http://www.minifreunde.at/harry/projects.htm
On 26th Mar, 2010 TurboHarry said:
Hi Guys,
Harry
have you a dyno sheet for this harry ? what boost are you running ?
thanks
robert .
TurboHarry
Member #: 115
I was on an old Bosch dyno to optimize ignition....it made 225hp at the crank at 1 bar boost at 7800rpm (LT inlet, RS exhaust cam), the max I ran on the street was 1,2 bar.
The compressor map of the GT 2056 is very broad and effective - I took the CHRA and turbine from a Mercedes (V-band) and fitted the bigger 56 compressor from another turbo....IIRR it was from an Alfa, but no sure anymore?
If I could join the RR sessions in England easily I would run for sure more boost...*smiley*)
http://www.minifreunde.at/harry/links/turbo.htm
thanks harry thats a good no. for the boost ,revs are high ,did you get a print out of the dyno run i could see ?
TurboHarry
Member #: 115
with both RS cams I had max power > 8000rpm, engine came on the cam at 4500 - was no fun to drive for me - so I installed the LT for inlet and the engine came to live 1000rpm earlier and loosing nothing at the top - will try both LT cams end of this season.
should have one picture of the dyno runs, but's on a different computer - will have a look for it.
excellent website *wink*
excellent , is that with a stock head ?
TurboHarry
Member #: 115
No - head is ported!
stock sized valves or huge massive race valves ?
TurboHarry
Member #: 115
stock valve sizes - 3 angle valve seats....
advantage998
Member #: 1840
Kings Lynn, Norfolk
What sort of price should i be paying for either a new/recon unit or a second hand unit?
This is the only one I can find:
http://cgi.ebay.com/ebaymotors/GARRETT-GT2...sQ5fAccessories
The important number is the 751578.
They rarely come up secondhand.
Nick
Member #: 154
Midlands
yup, they do seem pretty hard to get hold of. i managed to drop lucky with mine on ebay, not letting it go either, lol.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Yeah was gutted to have missed one a couple of months back went for £100 and was only delivery mileage.
Think i might have to look into an alternative.
I paid £140 for mine. virtually no miles in its original box.
Users viewing this thread: none. <- Prev
