Home > Help Needed / General Tech Chat > What's a 2.76 final drive like?
Mark??? Have you got loads of CWPs??
At a guess I'll think that the pinions wear between 2,76 and 4,3ish times as fast as the crown wheel :)
I'd say you're right vegard...
Phil1380
Member #: 314
Must learn to read better, I thought he said 3.76.
lol,
Hold on lads, I ve got an idea............
Hedgemonkey
Member #: 360
We all make 'em sometimes. Stupid comments that is. What a prat!
I was thinking, looking at a set I had, one of the mainshaft bearings was really shagged and the resulting movement had caused the whole assembly to move and caused massive wear on the pinion teeth. The crownwheel was A1, even on really close inspection. Hence stupid comment.
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89<br> Supercharging minis since '04
2.7 should be perfect with the supercharger and its no lag low down torque delivery,
it makes 1st gear a useable one rather than just a wheelspin demonstrator ,
they are easy to get hold of as lots of low power mpi owners change them , expect to pay around 75- 100 quid though
take it from some one who has tried an m45 setup with a 2.7
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
ANy blown mini sould go really well on the road with a long diff...
We have the torque all other forms of tuning are missing!
alex
AlexF
minimark
Member #: 19
newcastle
vegard ---- yes thanks , but i hoard everything!!
OK. WHat do I have to do to achieve one of these precious items of yours then?
minimark
Member #: 19
newcastle
make me an offer that makes me wanta sell .
£20
minimark
Member #: 19
newcastle
you missed a nought out !!!!!
and not £020 !!!!!!
lol.
£20.0 ??
minimark
Member #: 19
newcastle
ah , never said you missed the point out.lol.
I wish I could have a taller diff on my mini, one draw back of an LSD is you are restricted on FD choices
Hedgemonkey
Member #: 360
How far can machining get you?
As far as I know 3,46 is the tallest available.
You can get 1:0,93 drop gears from Minispares Jim. Will improve matters slightly.
thought it was 3:44 was the tallest?
still not that tall though.
I guess the OD of the diff flange could be turned down and the bolts re-drilled to allow a 3.2 or 3.1 , but not much more...
I'd have thought it'd be easier to get a gear cutter to make you a new idler gear(s) and do it properly. I can't understand why overdrive drops aren't available - they'd reduce the torque in the gearbox (by the ratio), making things much better all round for us guys...
Hedgemonkey
Member #: 360
Would I be right in thinking that having overdrive drops would load the idler bearings more?
If I remember rightly, there is an LSD which fits a normal crownwheel. Might be a cam and pawl one though. I have resigned myself to not running one.
vegard, i have those drop gears to go in
