Home > Help Needed / General Tech Chat > Minifin Troubles
sim_ou_nao
Member #: 114
Porto/Portugal
F*ck... I have my shoes upside down *Punch*
Pedro Silva
Just to add, the "funny slot" is in tech language called the "tit". Ref: Rich at MSCN
I take it Nic will adore this.
svrdaniels
Member #: 3600
Gateshead
Got it sorted, replaced the UNIPART brake shoes with some Lockheed ones and it all fits together sweet. Can only assume that there is some minor manufacturing fault with the UNIPART shoes. Picture shows the CORRECT orientation of brake shoes for the N/S.
Thanks everyone for the useful comments.
Simon
mowog
Member #: 6792
Have you also over-looked the obvious? Have you measured the ID of your Minifins? should be 7" (maybe a lttle more if worn or machined). Also measure over your shoes as assembled that they are just under 7"
Good advice, but again, two months late. The issue had already been resolved.
There is clearly a difference in shoes as the lockheed ones fit where as the Unipart ones dont.
t3gav
Member #: 229
Gavin@minispares.com
kent
Old thread i know but is the above pic definately correct? If so the minispares pic is correct also (apart from you have to turn the pic round 180 degrees) ?
1972-ANGUS
Member #: 3894
sallys gap. garden of Ireland
this is a setup shown for a twin leading drum front brake.
in my opinion, a rear drum should have both rectangle slots at the bottem, as the hand brake ones. ie. leading shoe for forward, and leading for reverse.
spring joins the oval ones
I had to grind 3mm off the end of a set of my brake shoes as they were longer than the set that came off. They were also unipart ones.
Measure the unipart shoes against an old one, I bet they're slightly longer! *wink*
To answer that particular question, I still believe the answer is yes.
The leading edges of the shoes should both be against forward braking and the small rectangular slot is for the plain ended bit of the linkage and the "C" shaped slot (the "tit" as Vegard put it) is for the pivoted end of the linkage. It allows the pivoted end to "twist" inside the "C" shape as the pivot pin wears.
It also make sure the return springs have one round hole to use first, then a slotted one to use second.
Also important - not shown in the photos above - is making sure the linkages are on the correct side of the car if they have been removed or renewed - they are handed so to make sure the long part runs parallel with the return spring, as shown in the MiniSpares photo even though it is upside down....
t3gav
Member #: 229
kent
Cheers Rod, i'm sure the handbrake levers are identical though?
t3gav
Member #: 229
kent
Actually ignore me i see what you mean now, they are identical but the pivot would be the other side :)
Well, I used to share your opinion, but this is not correct...
graemec
Member #: 1424
Carnforth, Lancs
The MiniSpares picture does indeed show everything assembled correctly.
It's just a bit misleading when the whole thing is shown upside down compared to how it is on a car!!
Yes, they are superficially identical but actually mirror images of each other, as per MiniSpares catalogue http://www.minispares.com/Product.aspx?ty=...E%20LEVER%20KIT
EDIT - and in the MiniSpares picture of the linkages alone, they are also folded the wrong way..... rotate the short bits by 180 degrees around their pin leaving the long bit stationary, then it will be correct :)
Edited by Rod S on 25th Jan, 2010.
