Home > General Chat > Can you guess what it is?
Mini_Andy
Member #: 432
On 27th Sep, 2009 Rob H said:
As they say there's only one way to find out?
FIGHT ?
On 28th Sep, 2009 AWDmoke said:
One of the boys over here made his own from a (very) used mini speedo cable and a $5 hall effect sensor
Neat - that's a very compact hall switch. Was it the type that needed a magnet (the little cylindrical bit in the nylon bush) or just a piece of steel ???
AWDmoke
Member #: 713
Western Australia
Can be used as a notch sensor, i.e. no need to glue a magnet to any spinning parts. I'm sure there is something similar available in the UK
Here is the data sheet: http://www.jaycar.com.au/products_uploaded/ZD1902.pdf
On 24th Dec, 2008 Nic said:
Shame about the price
http://cgi.ebay.co.uk/Isuzu-Elf-Speed-Sens...id=p3286.c0.m14
evolotion
Member #: 83
Glasgow, Scotland
a rover electric speedo sensor from any rover with an R65 hearbox should screw onto a mini speedo cable output or atleast bodge on. teh drive is the correct size, only issue may be the thread.
Denis O'Brien.
